- Oct 20, 2008
Mark, I did orient it that way on purpose after checking the grain on all the block faces. Didn't know about the flash of color though! Actually, I'm seeing that in the handle now... speaking of which, here's another update.
I worked on the dagger most of the morning, but around 3 or so I wandered over and picked up the kukwie project. The epoxy felt good and set.
First order of business was to rough the sides clean on the grinder to have a look. Here's the result:
You can see a bit of glue line near the end of the tang on one side mainly. Since the epoxy is black, the glue will disappear later- I'm not sweating it. This being my first keyhole handle, I'll be fitting subsequent models tighter.
Second order of business involved drilling the pin hole through the handle block, and upsizing it to 3/16". I put a stainless pin through, and hammered it tight on both sides as I would pins for a bolster. The idea was to swell the pin in the tang metal, and thus to be able to grind it flush. I didn't want a domed pin creating a nub in that part of the handle.
I ground the top and bottom surfaces flat. Not a perfect color match with the pin, but good. I like it.
And then I got carried away and completely shaped the handle and bolster, and sanded up to 220 grit before taking more pics!
The glue line completely disappeared, and the fit looks eerily perfect now. I'm actually very happy with how it's going. I slapped a coat of teak oil on it before setting it aside. I'll be putting several coats on as I sand it finished.
At this point I'll concentrate on the hamon polish until that's done, then finish the handle up. Stay tuned for more!
