skammer said:
One thing is for sure there is public perception and fear of large blades. Its ingrained in us from childhood by people and the media that blades are wrong. So it makes sense that the larger the wrong the more negative attention it gets.
The discussion used to be balanced, Mike Swaim for example on rec.knives wrote frequently both on the cutting ability of small blades and the chopping ability of large ones, machetes and khukuris mainly. The rants against big blades are the same as the rants against "concrete" chopping, they have nothing to do with a fear of large blades.
What is big and small of course differs, in Fike's video he constantly refers to a knife with a 16" blade as a small knife but this is from a sword perspective. I have showed a Battle Mistress to a maker who forges parangs and he described it as a small knife, not for "serious" work, and he is right given what he meant for it to do, lots of brush work with a blade that small is tiring.
Arguing that "thick" knives can't cut well is just silly when you consider blades from people like Fikes and watch the guys in the ABS competitions, and if you are not into swords and such then just look at Boye who used up to 3/8" stock in really small knives (4" blades), but they in general cut very well because he understood primary grinds.
Really thin knives are good on some media of course, I have knives with 0.050" thick blades, they cut really binding materials like thick cardboard much better than the Ratweiler.
skammer said:
I can split a minimum of 10 times faster with a large blade with little effort and no wedge making ...
Depends on the wood, if it is well seasoned and cracked open, and you have a bunch of wedges, which can be easy to make in some conditions, the wedges could be faster. You could have one knife and a dozen guys, you can then split a massive amount of wood by just giving them wedges. You can fly apart a large log like that in a chain gang, it is pretty amusing to do, you start at one end and basically just hit the wedges like a wave and CRACK the log falls apart. You really can't do anything like that with just one axe or knife.
Survival isn't always just about what you can do and it doesn't take much skill to pound a wedge in a crack, but giving a novice a big blade or axe and asking him to split wood could end up with another survival situation as they mangle themselves. I have seen wood though which was so horrible that you can actually split it faster with a long knife by batoning than with a maul. You can't really bind a large blade in wood, you just have to hit it hard and I have however seen wood take a maul and two wedges and refuse to split.
Thomas Linton said:
I find it curious that advocacy of a "big" knife for survival purposes gets (crudely) panned as irational by some when a "big" knife is advocated by Ray Mears, John "Lofty" Wiseman, and Ron Hood.
Not to mention the constant references as to the use of scandinavian knives as if they were the only culture who used knives. What is more amusing is citing Mears which is frequent in the arguements against long knives when he appreciates both types of knives. I would be curious as to his take on knives with primary grinds vs the scandinavian bevels, I really can't see how anyone would favor that style of grind against multi-bevels, aside from cost of course.
North61 said:
all these tasks for me are served better by a small axe and not as well by a big long and thick knife.
How thick is the poll on your axe, does it make it a poor cutting tool, why not? When people discuss axes do they frequently measure the thickness of the poll and then use this to judge how the axe cuts? What does the bit of a hardwood axe look like compared to a soft wood axe? Is the "thick" bit on the soft wood axe a bad thing or does it make it actually cut the wood better?
I like axes too, have a bunch of them, use them frequently, cut down over ten cords of wood a year with them, limb it out and split it. Would much rather use a parang to limb out the trees and the surrounding brush, and would never choose a small 3-4" knife to do any of that efficiently.
Use a saw to buck it mainly, though I bucked over a thousand rounds this year with blades and small axes, time consuming but way more fun than using a swede saw, though if I had as many high end swede saws as I had axes/knives I might feel different.
I have seen Mors Kochanski take his 12.00 Mora and quickly split two wood wedges off of a 12" Spruce log. Started a crack with his mora and a baton and 1 minutes later we had 6 peices of fire wood.
I have seen lots of wood eat wedges, twisted grain, chain and rings knots, I split some wood yesterday that had starburst patterns, those are kind of interesting to split. Surely Mors noted to you that there are massive differences in wood types and what seasoning can do to grain and that often wood can require multiple wedges or wedges of different tapers (just like axes need different grinds) and wedges can break (really easy if you consider stress in a survival situation) and other methods can be more optimal. He did show you how to use a large knife and have you try both on a wide variety of woods right and see which methods match your skill and physical ability and then tell you how someone with a different level of skill and physical ability would find different methods optimal. And he of course showed you quality examples of large knives made for wood working not some large tactical knife like a SOG SEAL and use that as an example of why "thick" knives don't cut well.
Safer for me in a thicket than swinging a heavy deflectable and sharp object.
Jim Aston, one of the heaviest proponents of the scandinavian grind, discusses dangers of long blades in clearing heavy brush, he however does not use this to advocate switching to a light utility knives and cutting the sticks individually using two hands. I would really like to see that arguement pitched to a native using a parang, bolo, golok, khukuri, machete, etc. . Watch Mear's "in the jungle" use long knives on both leafy and woody vegetation, while he has his scandinavian blade on his belt.
I could make a very thin bevel on the Camp Tramp but I'd still have a big thick heavy blade with a somewhat silly edge.
The edge would be
thinner than on the Mora not thicker. To be specific, for the edge on a typical 1/8" scandinavian blade to just equal the thickness of the edge on my battle Mistress the bevel has to be 0.65" wide, because that is how high you have to go on the Busse for it to hit 1/8". Mine was one of the early ones with thicker stock, the new ones have thinner spines and thus the primary profile is actually thinner. You can actually see what that edge looks like in the pictures of my Battle Mistress because the edge I run on it is actually more acute than the edge on your Mora's unless you have modified them.
As an aside, awhile back Matt Lamey dropped me an email about spending some time with Fikes and wanting me to have a look at one of his knives, I asked him would it be alright if I did a passaround, he had no objections. If he does find the time I intend to do it. I would really like to see all the anti-long blade guys participate in the pass around.
-Cliff
