cpirtle said:
Why not try to get the manufacturers to offer that design in a different locking mechanism? They don't want to because LL's can be made much cheaper.
True, a liner lock is a cheap solution. But I think there's more to the problem.
What alternatives are out there, really?
Frame lock: Stronger, but just as hard to do right, if not moreso. Same fit and wear issues (sometimes worse), not really well suited to mass production. From a design standpoint, it limits your handle design to solid slabs of metal; those thick slabs of metal also tend to be expensive compared to thin sheet stock and scales.
Lockback: Spyderco has shown that they can be even stronger than a liner lock. Still, a lockback requires an extra moving part, a couple extra pins, and some very tight tolerances to do right. And if it's not done right, the result is just as bad as a bad liner lock. I've seen some truly appalling lockbacks from China and Pakistan; crap is still crap, no matter what lock.
Axis: Sure, it's the best lock out there, but it also belongs exclusivey to Benchmade. Cold Steel, Schrade and SOG have tried to come up with similar designs that don't infringe Benchmade's patents, but none are as good. (Schrade & SOG moved the locking bar to the top of the knife, Cold Steel uses a channel in the tang rather than the edge of the tang; both take up a
lot of space, making for bulky knives. No way any of these alternative designes could be used in anything as svelte as, say, a Benchmade 770, or even a 710.) All three share enough features with the Axis that they might infringe BM's patents; so long as they only use them on a few models, Benchmade is less likely to unleash the attorneys, but if they were used more widely, Les might change his mind. Oh, and the Axis lock isn't easy or cheap to produce; Benchmade even scrapped their planned improved version (BM 780), because even
they couldn't manufacture them to their own high standards.
Rolling Lock: Also belongs to Les; see above. SOG has one that's similar, but with the lock bar up top, used on the Flash series; seems to work well, I'm surprised they haven't used it more... again, see above about attack-lawyers.
Compression Lock: Ditto, but subsitute "Spyderco" for "Benchmade". Again, a brilliant solution, but proprietary.
Now, there's nothing to prevent, say, CRKT from licencing the Axis lock. However, they're after the mid- to low-end of the wider market, and the licensing fees would make their product less cost-competitive, especially versus the cheap knock-offs. It's a business decision: while the Axis would be a better lock, a decent liner lock with LAWKS is cheaper; the cost/benefit of the Axis loses badly.
Like everything else in business, it all comes down to money. Spyderco and Benchmade and their ilk have made the decision to make more money per knife off fewer high-quality knives, despite the fact that their market oppotunity is limited. CRKT and Gerber and their ilk have decided to make "good enough" knives, make less per knife, but make more money by selling more of them to a bigger market that doesn't appreciate things like 154CM steel or Axis locks.
(What CRKT and Gerber don't seem to realize is that they're now competing with the Chinese knock-offs, who don't have to worry about wages or legal liability or safety or any of that; hence, they cannot win. Look for Frost to buy out CRKT about five years from now, just like they did to Schrade.)
