I was going to suggest the Baklash, but..... the Ruike P-801 @ $30 is as solid as anything under $50![]()
Kershaw Induction
I've run across that Harnds Talisman multiple times in my searches, and it always appealed to me. I've been tempted to pull the trigger on that knife for some time, so I've been on the fence on it, and I'll take the plunge now. I've heard of the Santa Fe, but don't much about it. I'll check that one out, too! Thanks, buddy.You've got some of the best listed. The Civivi Baklash might be my pick for "best". I also like the Naja but it is discontinued. Civivi does a stellar job with their 9Cr18Mov. It's like the difference between average 420HC and Buck's 420HC with the Bos heat treatment, only from a better starting point. I definitely prefer it to D2.
I finally had a chance to try the Ortis. I really wanted to love it but a single issue prevented me from doing so. The lock bar has toothy jimping that stands proud of the scales. During use, it routinely caused a major hot spot for me. I also have this problem with my Rat 2 but it's nowhere near as bad.
Overall, the Rat 2 is a good knife at a great price in AUS-8. It snaps open nicely. The blade is thin and slicey. They do a nice job with their AUS-8. (Their D2 doesn't offer enough of an increase in edge retention to offset the higher price and loss in corrosion resistance.) Other nit-picky issues that hold this one back are sharp riser jimping and lack of skeletonization. The closest competitor in the $20-30 range is the Tangram Santa Fe by Kizer.
The Santa Fe is a wonderful little knife. The ergonomics, thin slicey blade, action, and steel performance keep it in my EDC rotation despite owning more expensive knives. It uses Acuto 440, a Japanese steel with similarities to 9Cr18Mov. While not as good as 14C28N, it's easily better than AUS-8. I've taken several of these apart and given them out as gifts. The only issue with Tangram seems to be a little hit or miss QC. For instance, the grind on one was a little off and one had its washers the wrong way. (They should be three per side but one was four and two from the factory.)
Another notable but seemingly obscure knife under $50 in AUS-8 is the Harnds Talisman. It has fantastic ergonomics and honestly some of the best action on any sub-$100 knife. They do a nice job with their AUS-8 but it is still AUS-8 for $40-something. While still better than the 8Cr13Mov in a Tenacious, that is the only thing that keeps this from being a "best" for me. If that isn't an issue for you, it's worth checking out.
What's the difference between the Tangram Santa Fe and the Amarillo? I couldn't find the Santa Fe. Thanks!You've got some of the best listed. The Civivi Baklash might be my pick for "best". I also like the Naja but it is discontinued. Civivi does a stellar job with their 9Cr18Mov. It's like the difference between average 420HC and Buck's 420HC with the Bos heat treatment, only from a better starting point. I definitely prefer it to D2.
Buck 110 is an essential part of any knife collection.
For me, it's been the Riuke P-108. The Buck 110 is a close second, and a classic.
I should mention, the only reason the 110 comes in second is that my EDC is a fixed blade, 95+% of the time. But to carry a 110 means leaving my FB at home, they occupy the same spot on the belt.
Agreed!If you can go up to $100 you will open up a lot more options, Seki made Spydercos, Steel Will models etc
If saving up for this, maybe wait a little longer and be able to get a higher quality knife that will be of more value to you long term with better steel etc
