Wow that is crazy, do you have a link of that video
Would you say that it is tougher than elmax?
How do you like it in that axe? I didn't care much for S7, and would like to try S5 to get something with some more hardness (and better toughness to boot, too bad it has lower availability)
I think Scrapyard knives uses a modify S7 and its pretty good, but what about using Cpm 1VH13 likely wasn't mentioned due to its lack of visibility in knives. Being a hot work steel that only reaches the low 50s in hardness, it probably isn't very common in suitable sheets nor particularly popular with makers. How do you like it in that axe? I didn't care much for S7, and would like to try S5 to get something with some more hardness (and better toughness to boot, too bad it has lower availability)
What about H1...doesn't hold an edge all that well in PE but is very malleable...![]()
Randall made knives for NASA, and they don't use INFI, CPM steels, or anything terribly exotic.
Out of this list (Niolox,Elmax,Vanax,s35vn,cpm154) or to any steel of your knowledge, what is the toughest Stainless steel today?
Also could you compare its toughness to other carbon and stainless steels.
i've hammered one of my knives through car doors, 4 pieces of aluminum deck plate, batonned through solid hardwood and cut a deer antler in half with no visible damage... and it's just plain 440c.
if you mean INFI then you definitely do not recall correctly
I may or may not recall correctly and that website is no longer available to consult with. I'm pretty sure it was a large Busse knife but I'm not familiar enough with the brand to know what other steels they might use.
There's no question about whether or not you recall correctly. You do not.
