I read this thread and couldn't think of anything. So I actually walked out there and couldn't think of anything. So I poked around and still couldn't think of anything.
How depressing... I have a nice shop full of tools I only used to dream about. And I'm about ready to drag the entire lot out back and set it on fire. I could use a break from machining, too much of it this year.
But. Way out back, at the rear of my property, there is a filthy workshop with two dusty windows, and a couple flickering florescent lights that illuminates a dank dark dusty mess. This is where I keep all the dirty stuff. A big metal rack full of old oily drops and one ton of greasy 1018 CR. Grinders (not my KMG, Rob), tumbler, welders, plasma, saws, even an injection molding machine. Nasty dirty filthy mess making stuff that I keep far away from my nice clean precision shop stuff. In this dark dusty shed, with an old window AC unit rattling away, and spider webs everywhere, there sit the worlds finest welder. A big fat Lincoln square wave TIG welder with a water cooled torch, that will go from 2 amps to 400 amps, and 36 volts to 80 volts, with wave balancing and adjustable everything. Set the high frequency arc start where you want it, turn on the argon and install an appropriate tungsten into a gas lens, step on the foot pedal and a soft glow will expand out into the air and find the piece of metal you're welding and stabilize into a smooth glowing arc. Step on the pedal, and push that powerful heat and start your weld, then back off. Then get it going again, dip your rod, move over and find your rhythm and make the prettiest welds you've ever seen. Welds as small a 1/32" or as big as 3/4". Welding steel as thin as a .035 bandsaw blade, or as thick as one inch plate in one pass, and as pretty as you please. Man I love that welder.
