- Nov 1, 2020
What knife would you buy right now if only it was made in Magna Cut?
I’ll start with one…
Esee Junglas!
Esee Junglas!
I remember New Coke.A Survive!
Just kidding.
Seriously though, we don't know much about Magnacut in practice yet. When iOS 16 will come out, will you install 16.0 or wait for the first patch ?
For example, M390 Spyderco vs. Hinderer vs. ZT are all different, significantly so. Will not buy an expensive Magnacut knife without some experience of the community first.
What information on the steel do you think is missing to make a decision about the steel? Seems a lot of manufacturers have jumped on or will be on the magna wagon soon. There is enough information out there for me to make my decision on the steel. Yes, there will be the “What Rockwell” variable, but it is safe to say that any reputable manufacturer will do a decent heat treat and will probably vary the hardness based on the intended purposes of a knife or find the Goldilocks zone. I want to see large hard use fixed blades in this steel for sure.A Survive!
Just kidding.
From what I have read, it will probably be in the S30V range of materials cost. It is reported to be relatively easy to grind too which makes it cost efficient to produce.Rat 2. Likely 90% of my day to day cutting needs could be covered with that. I have no idea how expensive that steel would be for manufacturers to buy and process.
Not disagreeing with you.
To be honest, I'm still not sure if I "need" it .... CPM Cruwear, 3V, Infi and AEB-L are still tougher, M390 is still more corrosion resistant. Toughness/wear resistance of Magnacut are right in between. Would be cool to try a Magnacut Manix 2 for $120, but (for now) to put all bets on it to buy a more expensive knife - it's just too early, I feel.
