I have just started to really get to grips with my grinder. Also, after years of using nothing but wood, I have discovered the joys of Micarta
Style: Bushcraft utility
Blade steel: Full quench O-1 tool steel with vinegar etched finish
Blade length: 4 inches
Grind: Full flat with convex edge
Blade thickness: 1/8th stock
Weight: 5.5oz
Handle: Black linen Micarta, box tang construction, brass hidden bolts
Overall length: 8 7/8 inches
This is the bigger brother to the knife at the top
For someone who likes a little more blade length.
5 inch blade, just fractionally under 10"oal, canvas Micarta handle and brass bolts/tube. Again, flat ground and etched. This shows what happens when that vinegar etch is a bit too wet
more black than grey and fewer blotches.
I just put the finishing touches on this last week It was modelled after a the one at top, but I was asked not to put the vinegar etch on this one.
Specs are basically the same as the last one. 1/8 O-1 at 4" long with a flat grind and convex edge. Linen Micarta box tang handle and brass bolts. I got to play with some new grinder belts on this one, both extra fine Scotchbrite, and a 400grit cork belt. I rather like the effect
Beats the heck out of hand sanding everything!
One new feature is the variable spine radii that I am playing with these days. Ideally a spine is nice and round to be gentle to thumb pads when doing detail carving, but if you are into bushcraft and playing with ferrocerium rods, you probably want a square spine to scrape sparks with. Having seen what a really sharp sparking spine did to a friend's hands, I started applying partial rads to my spines. It looks a little odd, but as a compromise it does seem to work.
