- Sep 12, 2011
Do I need water stones or am I alright with just buying a dmt diafold? Trying to get my new ratmandu sharp
Do I need water stones or am I alright with just buying a dmt diafold? Trying to get my new rmd sharp
the setup you mentioned with king stones at less than $100 seems alright. Its a swamp rat ratmandu that Im sharpening but I do plan on picking up an esee junglas eventually so I guess the water stones would be a decent investment. To answer your questions I'm in Calgary and no, I havent even sharpened a damn axe before heheheh. I figure if I can teach myself how to reload without blowing myself up I'll be okay with sharpening.
Canadian, it depends on what you're primarily sharpening. I'll give you a little glimpse at my issue with SR101 and my sharpening experience. A vast majority of my blades are high carbon, and those few stainless models I have are softer 57-58Rockwell hardness. This puts me solidly on the stone side. I bought a HRLM about six months ago and tried to lighten up the final bevel's angle a bit, but my stones really wouldn't touch it. The steel is too hard and the grain too small to get anything done on Swamp Rat's steel with water stones, though they were the perfect ticket for everything else I owned. At that point I acquired a 3x8x2 chunk of oak, varying grits of wet and dry sandpaper, which is more abrasive even at similar grits (and harder) and proceeded to tack strips of wet and dry to the wood block to make an 'ad hoc' stone that was hard enough to be effective on SR101. If you tried to get anywhere with a steel that hard on a nice set of stones, you'd probably wear them to a point of uselessness, spend so much time and water or oil in the process that it wouldn't be worthwhile, etc. At the same time, I wouldn't go as far as using diamond stones on my blade, especially for reprofiling, and I really don't think those DMT stones are robust enough to get much done in the edge thinning department. Wet and dry is the ticket for that badboy IMO. Save the King stones for your nice bushcrafting blades and burn disposable GatorGrit on the supersteel.
right sorry Jim- probably mostly at home.
Hey thanks guys all good input I know 100 times more tan I did this morning. If I can get better stones for the same cost would you mind sharing which stones you're talking about?
I know this very well knifenut. As you know I did considerable research in many subforums before investing a hundred dollars as a college student in that knife-and I do just as much research in every product I buy. Anyone that has used or sharpened SR101 will tell you otherwise=just because of its chemical relatedness to 52100 doesn't mean that its physical properties as turned out by the Bussekin plants doesn't put it in the running with 'super steels'. Grain size, alloy distribution, heat treat etc. are much different than the typical ballbearing steel. Waterstones cut faster than sandpaper up to a certain hardness, but after tearing up a set on my HRLM and seeing no results on even the finish of the edge, determined that the steel was just too hard for the stones themselves. I guess I should have referred to DMT's duohone products as not being robust enough. They're too small to be efficient and get clogged too much to remove material in quantities that would allow you to reprofile a blade. They make great pocket and pack sharpeners for on the go touchup but for maintaining a blade long-term or reprofiling as a 'one stone' they just aren't the tool to use.
