What should my first HI purchase be??
Well, I'm no professional, but, here's how I see kukri, and a lot of guys may disagree:
I like the big battlecruisers, that's no secret. I deliberated for 4 years about getting a kukri. Primarily I wanted it as a wood processor, and I wanted it to perform as well or better than my 19" 1 3/4# head axe. I kept mulling it over in my head, and kept coming up with the 20" CAK as the solution. It helps that it is "Armageddon Ready" as being the only one warrantied as a prybar.
It chops far better than I hoped, and much to my surprise, when I put a shallow convex grind on the bevel and polished it up a bit, it cuts light vegetation quite well also. The reason I like the weight, is I found I can do a lot of the lighter work by simply raising the blade to shoulder height, and letting it fall -- making gravity provide the impulse, and me simpyl guiding it on target. In the long run, I think that's less work that snapping a lighter blade. That opinion has been reinforced after using blades like the sirupate and tamang. Now, In tight places, where you can only use short snaps, the tamang is the weapon of choice.
My size: 5'10", about 260 right now. My hand is 4.5" across the palm, thumb not included. Smaller guys WILL NOT agree with my choices. The larger guys tend to agree. The other thing on the size of the kukri is that they scale them. A short kukri will have a proportionately shorter handle on it. I find kukri less than 18" to be too short and light to take full advantage of the design, and the handles too small for my hands.
The 20" CAK is not something you want to swing in a fight all day, however if you are big enough, you can wield them surprisingly well, they stab well, a swing will remove whatever it hits, and from experience, I can say they have a definite intimidation value.
If you are going to buy a big kukri, find one you like, and it will be much nicer to carry and draw if you have a custom quickdraw sheath made for it that has a belt loop and also a baldric strap.
Ok so recommendation for a 18-20inch 1/2+ thick kukri? I prefer a full tang- for many reasons, but i guess it's not necessary... I just greatly dislike hidden tangs if I have other options
Cpl- what was that you said about a r-10 knife? What's that??
The 18"+ M43s often had 1/2" tangs (correction: SPINES), but several of us have requested thinner ones like they came before, so that might not be guaranteed anymore. A 20" CAK will most likely come with at least a 1/2" spine.
The R-10 is the knife in the pic with my 20" CAK. It makes a fine general purpose/bushcraft knife. More pics:
Nice, neutral balance:
The baldric rig and R-10 sheath I had made:
The 18"+ M43s often had 1/2" tangs, but several of us have requested thinner ones like they came before, so that might not be guaranteed anymore. A 20" CAK will most likely come with at least a 1/2" spine.
Afew things- nice sheath, the r-10 looks great.
Where can you fond the 20" Cak?
What did you mean by "The 18"+ M43s often had 1/2" tangs, but several of us have requested thinner ones like they came before, so that might not be guaranteed anymore."?
Do you mean a tapered tang? Because I can live with that- better than a hidden one any day- so that may be my way to go
So I'm thinking I'm ethier going for a 20" Cak or a m43
Ok so I've had almost all of that behind my thoughts
Sorry, I meant the 18" M43s had 1/2" SPINES for a while, but some of us have requested thinner ones like the 3/8th spines that they originally came with. The M43 uses a pinned-on Chiruwa style handle (though not warrantied for prying, like the CAK is, if that's a requirement of yours). But we wanted a return to the thinner, lighter models (and the one I requested was with the handle ring, which I have come to desire greatly on a kukri), as it's more of a balance between martial and utilitarian uses.
The CAK, on the other hand, is geared toward the utilitarian uses, and can also be used for martial purposes if you are strong of arm, but it is heavy and not well suited to primarily be a fighting knife. For as long as I've been here, the AK/CAK has been the big bruiser chopper of any given length.
Ok...
Fighting capabilities aren't important- I could make it work if I needed too
So then where do I find a 18-20" Cak? I don't see them listed(or do I?)
Email Yangdu for one.
HIMIMP@aol.com
She MAY have one in stock, there MAY be one or two on their way.
When I got mine I hadn't seen one for sale online for the entire time I was deliberating over buying one (one reason I hesitated, I never saw what I wanted for sale), and ended up emailing and asking to have one made.
One thing you need to understand is that the HI store has only a small fraction of the models that HI has/does offer, most of the new pieces are posted here as deals of the day and such. Check out the links in my sig line for listings of a lot (but not all) models that have been offered.
I recommend getting in touch with HI about it. They'll know, according to your body type, experience, and intentions, etc. what will be best for you. I just got the Chiruwa (16.5) and it's pretty heavy, I'm about 6'ft and the blade length suits me just fine. On the other hand, I know that if I was a bit stronger, I could really handle this thing with more authority. It is a really awesome chopper! Are you looking for pure self defense, or are you looking for more of a work horse? I recommend the CAK for serious, heavy duty work. For SD I might say get something lighter, maybe WWII, Sirupati. I only own a CAK, but after using it a while, I want my next kuhk be a bit lighter. Right now I'm looking at Sirupati, WWII, and Chitlangi, maybe Gelbu Special, I need a good comparison on these puppies to really know what I want. You'll get something awesome either way.
Email Auntie for it. Share with her about your application.
I would go for WWII.It's simple khuk for beginner to handle and slowly move up to acquired taste. But then again i was really into CAK.
For someone who was eager for 1/2" thick spine, i now opted for 3/8" for choppers and 1/4" or less for SD. I'm only 5' 10", 140pounds so huge chopper would tire me down.
They don't have have any 18" caks but they haven't said anything about the 20s...
Oh yeah- I plan to use it as a... As a I use all large blades for- whatever I need too- chopping large amounts of wood, safely, cutting things(duh) actually I think I'm mostly going for wood processing, and I'm sure intimidation will fit in there somewhere too...
For wood processing any of the Ang Kholas or Ganga Ram Specials would be good.
Im getting a m43 for my fidst hi putchase i think itll be a good all around medium kukri....
I'm also getting a chiruwa grs from moogoogaidan
It is exactly what I'm looking for, for what this thread is about- after i get me a real chopper I'm open to all other kukris- yay! My wallet thanks you!
Thanks moogoogaidan!! :D
My next purchase after the m43 will ethier be a r-10 or a ak Bowie- Proubly both ;)
Sent you an email, XanRa!
So everyone knows- I have settled on a 20.5 chiruwa grs from moogoogaidan
It is exactly what I'm looking for!
Not entirely happy that a sale was made here on Aunties showroom floor, potentially costing her a sale.
In the future this type of thing needs to be handled completely privately, or posted in the approprite FS forum.
I hope you all understand.....
Very sorry Karda -- I e-mailed him first without posting on the thread but he didn't notice it. I just wanted to give him a heads up. The GRS I sold him was posted on the FS forum, I'm sure he just never saw it. I didn't mean to ruffle any feathers, I just know that if I was looking for a pretty niche item, i would love if someone alerted me to where I might be able to purchase it. But I understand what you're saying and it certainly wasn't my intention to come off as a scalper. Sorry again -- happy Friday! :D
Don't look at it that way, please don't- I'm sold on Himalayan imports now and it will NOT be my last purchase-
I already have my next 3 or 4 already planned :)
Look at it this way I'm getting a m43(because of this thread) I just happened to pick up a grs too
XanRa-you have mentioned the AK bowie several times-it is a superb short(9")bladed chopper that I highly recommend.I love the kukris,but do yourself a favor and get an AK bowie!!
