- Sep 10, 2007
So you don't think cardboard would chip/roll 20cv?
Best guess. No. Not at the edge angles of the griptilian and not much more or less than the others on your list.
Salata likes men!!! And vibraters
Awesome thanks! So does toughness affect a knife's ability to cut through abrasive material? Or is toughness only how it absorbs impact.
Ok thank you! So if I plan on getting a tougher steel, it would be able to cut more abrasive things without chipping/rolling?
Not really. To give you an example, let's say you're cutting through cardboard and absolutely smoke a giant staple. A "tougher" steel will be more likely to roll at the edge rather than chip. Or you're cutting a zip tie and hit a piece of metal, it will roll rather than chip. The level of abrasivity of the material has no effect on chipping or rolling the edge. That is where edge retention comes into play. The higher edge retention a steel has, the longer it can cut without the apex of the edge suffering deformities.
I would suggest looking up cut tests on each of these steels on YouTube to give you an idea of what is best for your needs. IMO, Benchmade does their S30V very well. I have a knife in their 20CV and it performs almost identical to their S30V.
No. A “tougher” steel would bend more before snapping, or be less likely to snap due to sharp impact. Any of these steels is more than tough enough for cutting cardboard and the like.
A steel with proper heat treat and find grain structure = more stable at the edge, and therefore more resistant to chips or rolls.
In all honesty, you’re unlikely to notice a difference in toughness or edge stability in the application you’ve described, unless you catch a sample with a burnt edge. In that case, the problem would be belt grinding issues, not steel composition.
The take away here should be, “don’t sweat it. S30V is great for this.”
Awesome! and 20cv would work perfectly fine too?
20CV is fine.
The thing is, Benchmade has been delivering S30V closer to its chemical potential than they have been with 20CV. Properly treated, 20CV should our perform S30V markedly. As they do it, it’s just OK.
If you really want peak performance from BM, they seem to be doing their best work with M4.
That is really surprising to me. Thanks for sharing. Edge retention is dependent on what one is cutting, and I think this shows that well.154cm or s30v will be better for cutting cardboard iirc.
There have been tests showing its better in this task than the other options.
You would assume 20cv would be better, but it's not.
Tests done here and here
https://www.youtube.com/channel/UC76o8bpHyEpBaysM9Pr83Og
https://www.youtube.com/channel/UCI_ZXbN06A7W937hKKnUfqQ
Just know you'll have to sharpen it a few times regardless to get past the burnt edges from the factory grinds.
Edge retention is dependent on many variables. not just what your cutting, but the geometry of the blade, the geometry of the angle of your cutting edge. and how thin behind the edge it is. on top of that the heat treatment of that steel and lastly the composition of that steel. the burnt edge from factory grinds would affect it but id say thats more metallurgy related to heat treatment.That is really surprising to me. Thanks for sharing. Edge retention is dependent on what one is cutting, and I think this shows that well.
