All the metal used in it's construction is highly corrosion resistant.
Just put a drop of your favorite lube on each side the pivot.
I have carried mine for almost 15 yrs now-Only had it apart twice. Last time was about 6-7 yrs ago, and YES it's my EDC knife.
I use mine around salt water allot. I just rinse in distilled water and blow dry with compressed air. Add 2 drops of Marvel Mystery Oil and call it good-
LG
If he has never taken a CRK apart before I do not recommend it. They are easy to reassemble but the tolerances are super tight for a reason.
Thanks for the replies everyone.
I was mostly concerned about the grease than anything else, how it would react when mixed with oil or whatever. I'll use a drop of oil in the pivot, like I do in my other knives.
Crk says to use their grease because it has the best overall combination of lubricant and protective properties. Don't you use the type of oil recommended by your car's maker?
I have the CRK grease and the spray on Wd40 Lithium grease and they are distinctly different materials.
I asked the nice people at CRK and they said no oil or external lubricant is satisfactory, because low viscosity lubricants do not properly protect the pivot area from rust. To properly lube,,about once a year, take it appart, clean & lube with the CRK grease.
I wash mine in soap and water and dry with a paper towell all the time and I lube every 2 years or so. The blade always falls freely when the lock bar is pushed out to remove the detent tension. You can not get better "action" than that.
Take it apart when you do something wronwrong to it, like drop I'd in the sand, at the beach etc.
. Yeah, but you meet the manufacturer's minimum specs, that's not the same as using oil when CRK says to use grease. I bet you do not use oil to lube your ball jointsNo, because there are better oils than what the manufacturer's recommend![]()
