Hope the trip ended with a proper fix Dan.
Thanks Bob but I’m going to have to see an oral surgeon to have the root removed and then they can replace it with a fake tooth. Doesn’t help that I’m on blood thinners which increases the healing process significantly. But I don’t want to look like a hillbilly for the foreseeable future 😜
Kind of you to say Gary.
I believe you could be the US ambassador to the knife world.
Thanks, Bob. I don't have much knife knowledge compared to lots of folks on The Porch, but I don't know if that's considered a pro or a con for an ambassador. ;) Even if I were to be appointed to the position, I'm sure I'd soon be fired for lack of loyalty in the face of lunacy.o_O
Rough Ryder's version of the Case x318?
Seems the RR 603 (and a few others with different covers) (stainless) and RR 1740 (carbon steel) are their (affordable) version of the Case x375.
(RR leaves out the blade rub feature Case includes on their 2 spring stockmans. At least on all the RR stockman I have.)
I think of it as more like the Uncle Henry medium stockman (Schrade 897UH) than the Case x318; the Case 18 stockman has such a crazy high sheepsfoot, unlike the RR and Uncle Henry.
I got myself a RR1740 for Christmas last year and think it's a fantastic knife, even if it has square bolsters that I usually tend to avoid.
Out in the yard with a possum. Good times in Missouri :D
You posted several appealing "crotch shots" of your knives in trees around this time, Mike! :thumbsup::thumbsup::cool:
And yet I continue to play the lottery. No wonder I never win any money since I’ve cashed out already.
I suppose another way to look at it is to say that the plane incidents show you're on a hot streak and you're bound to win a lottery almost any day now! 🤓
Bladeforum Irish Jack...
Classy jack, Paul! :cool::thumbsup::thumbsup:
Bone bonanza, David! :thumbsup::cool::thumbsup:
Cool Cudeman with handsome horn! :cool::cool::thumbsup:
Posing next to milkweed, which is attracting many butterflies and hummingbirds.View attachment 3177443
Colorful photo and splendid knife, Bob! :thumbsup::cool::cool:
Our milkweed plants don't look anything like yours; northern and southern species, maybe?
A mostly cloudy start to the day here in the City by the Bay🌥️. Not much on the agenda for today other than to mourn the loss of a tooth that broke off after biting into a black cherry 🍒 too hard and catching too much of the pit. Not in any pain and since it’s one of my lower front teeth I’m hoping my dentist can fix it🤞. In the meantime keeping me company with a nod to Wooden Wednesday a fancy lamb and a hound. Have a great day folks! 😀
View attachment 3177535View attachment 3177536
Hope the dental damage gets fixed soon, Dan! :thumbsup::thumbsup:
The package appeared on his porch without announcement. No receipt, no note, though he suspected the brown truck he'd seen earlier as it rumbled down the street, had something to do with it. Contents revealed a small Mercator carbon steel non-locking folding knife with a copper handle and bail, made in Solingen, Germany. It slipped easily into his pocket. Once inside his home, he set it on the table and left the knife there for the remainder of the day.
By morning, it was no longer where he had placed it. Not lost, not hidden. Relocated, sitting parallel to the edge of the table, aligned with a precision he did not remember applying. He picked it up, opened it, and tested the edge against a scrap of paper. It sliced cleanly. Later, he used it to break down a box, then to slice an apple. Each time, he closed it and set it down differently, making a point not to think about it. Each time he returned, it had shifted again, never far, always deliberate.
He tested this more than once, changing the knife's position, then leaving the room. When he returned, it had moved, but the orientation was always the same. The pattern held without exception. He wrote it down once as a reminder, then stopped writing.
The next odd thing happened while making coffee. He set the knife on the counter, turned to retrieve boiling water, and came back to find it slightly closer to the mug than he remembered. Not much closer, just enough to suggest initiative. He ignored it. Later, he found it resting against a stack of unopened mail, as if volunteering for duty. When he left it on the table overnight, it appeared the next morning beside a loose thread on the shirt he had selected to wear. He clipped the thread, set the knife down, paused, and said out loud, “All right.” The knife did not respond, but it stayed where it was, which felt like agreement.
On the third day, he stopped moving it altogether. He left it in the center of the table and went about his routine. When he returned that evening, it remained where it was, unchanged, as if it had settled on its own terms.
He stopped pretending the knife was ordinary. It nudged itself toward boxes that needed opening, hovered near packaging that resisted tearing, and once positioned itself next to a tomato with quiet confidence. He began leaving small tasks undone just to see what it would do. One evening, he placed it in the middle of the table and said, “Anything else?” The knife remained still for a moment, then shifted slowly and pointedly toward him. He glanced down at the left leg of his jeans, already coming apart at the seams. He looked back at the knife and said, “Let’s not get carried away.”
I've heard that the high-tech Germans are installing AI in their folders! :thumbsup::thumbsup:🤓
Nice knife and boots, Lance! :cool::thumbsup::thumbsup:
Do you usually lace them up all the way to the top? I got some new work boots last October, with 2 pairs of those "speed hooks" or whatever they're called at the top of each boot. The right boot was "beating up" my inside right ankle bone, and I found out I could fix that by just using the top pair of hooks. So now I do that on both boots, just for a symmetric look.
I really like your knife with the little guy on the blade, José! :thumbsup::cool::thumbsup:
Another foggy start to the day here in the City by the Bay🌫️. Supposed to clear up but on this side of the City it’s a bit of a crapshoot. We’ve had it clear by midafternoon only to have the fog roll back in an hour later. Summer in the City 🌁. Keeping me company two from the vault. Have a great day folks! 😀
View attachment 3178409View attachment 3178410
Notable pair, Dan! :cool::cool::thumbsup:
Do you really have a "vault" of knives that you seldom carry (along with a "rotation" of knives that are frequent carries)?
Back on BF today. Been visiting with my Cardiologist for an EKG and an Echocardiogram along with Labs etc.. Nooooooooooooo Finger Waves. Didn't hear the snap of a latex glove one time. Turns out I've got a weak aortic heart valve. Will be able to continue with my normal routines - just at a bit slower pace. Carrying this Case/Carhartt single blade G-10 Sowbelly today. Sausage and biscuits for breakfast.
Glad you're back, ED! :thumbsup::cool::cool:
Any chance of doing a "valve job" as a long-term fix?
"The coldest winter i ever spent was a summer in San Francisco."
i'm away from my stash, so carrying the small tinker for the duration.
Frank, I've heard/read that quote several times, and I think I'd always seen it attributed to Mark Twain. But that was apparently wrong according to Quote Investigator (which seems quite reputable): https://quoteinvestigator.com/2011/11/30/coldest-winter/
Winning pair, Tyson! :cool::thumbsup::cool:
- GT
- GT
Likewise. That's why I omitted any attribution. The most i can say is, "Somebody said it."
Let me join the quote enthusiasm club ;)
That HSB 'Chopper' is a wonderful example. The Bingham shows great quality in construction and the unusual blade combination marks it as notable, it's interesting that so much detail finish is put on the Spey blade (it almost looks like a Drop-Point/Skinner) long pull and swedge. Must be quite a heavy knife, serious! Very nice condition these two, carefully used. I'm no fan of rusting hulks that some are besotted by-nobody wants the faux crocus of the buffer of course- but careful preservation makes for not only attractive but a viable occasional user too.
Thanks, Will
Thanks, Will
I think it’s awesome!
