- Oct 11, 2021
Thank you for sharing your experience. Although it's interesting, I don't think the example you gave is close to this situation. The process by which something is made is different from the materials used. And many knife manufacturers including Benchmade share what materials they use.I clearly have a different experience with companies and materials they use than you do.
We did electron beam welding. A lot of companies do electron beam welding.
Do you think that if we figured out how to join metals together to achieve a more desirable result that we should "happily" share that information?
We specialized in dis-similar metal joining. None of the materials used are "secret". All of the processes are proprietary.
Do you think if you called and asked that anyone would or should explain the specifics to you?
In any case, HAPPY THANKSGIVING.
I think liner material does make a difference especially with corrosion resistance. But if you think, "there would probably be little difference if they used one 400 series steel over another," do you at the same time think it matters much to a counterfeiter? I did not demand anything.Having had numerous Benchmades over the years, and using them plenty for tasks reasonably expected of folding knives (and a few that weren’t), I’ve never had a liner fail, not do exactly what it is supposed to, or just randomly explode. But I guess your not-at-all suspicious demand for their product information will never lead you to these same groundbreaking, scientific results I learned by using them if you don’t ever find out exactly which 400 series steel they use.
