What's going on in your shop? Show us whats going on, and talk a bit about your work!
got my lil grinding room mostly finished. Still gotta build a door, figure out venting and build some benches and other stuff. I decided to reuse the stand I built for the grinder way back when, which is pretty skookum, and being able to fine tune position is turning out to be pretty helpful so far
How are you going to grind log blades with the grinder so close to the wall? Will you be able to move the bench easily enough?
Did a quick and dirty sheath this evening with the machine so I could stitch an actual sheath instead of practice layers. Completely forgot to hand saddle stitch the lower belt loop holes before closing it, but the main stitching came out nice with the Cub! Trying to get some smaller needle sizes to try out. The hole from the 25 needle isn't filled too much with the 207 thread.
I tried backstitching the first few holes at the top end, but didn't hold the bobbin thread enough, so it broke, so I just pulled the stitches and redid it and left enough at each end to hand saddle stitch for the back stitching.
when I'm standing at the grinder, I can reach out both arms and not touch wall so I don't think I'll have problems there. But I can totally move the grinder around with a little tomfoolery, if necessary.
I got my lighting all figured out, so now all that's left is the install. Structurally, this thing will be done by the end of the month! Then it's sheath making, all of July...
The picture makes it look so much closer than it is in reality.
Got this thin, flexy ham slicer done yesterday! 9" cutting edge in 1/16" thick Nitro V at 62 HRC. It has a good bit of flex to it, which makes it a PITA to grind! Stabilized Maple Burl handles, red G10 liners and natural Micarta pins to match the other knives I did for the customer over the years.
It got flat ground and then convexed on a S2-32 felt platen to a zero edge and then sharpened. I hate sharpening flexible blades like this, but its stupidly sharp now!
Got home from the reunion. Grass was crazy high ... Electric Rider mower is still in the shop waiting for a controller board ... had to mow with the electric push mower.
Got it done and went into the shop to get a bottle of water. Picked up an axe head and a handle blank and went to the grinder. An hour later this was done. I made a boy-sized version of my professional throwing axes. It should throw from around 8 feet. Specs are - Weight 18oz, length 12". We have Judy's cousins coming for a BBQ in July. They are bringing their grandson, who is 8. This should get tested nicely then.
I wrap the handle from butt to head first with hockey tape, then I apply a paracord wrap part-way down. Before and after photos of the paracord wrap. I should have used a better background than my scared knees :oops:
On some full size throwing axes (16-18"), I do tsukamaki. It looks amazing on an axe. I have one I am doing for myself that I will post photos of the construction and tsukamaki.
