Back home now. I would have shared the following while it was in progress, but I have a phone that is sometimes a struggle to post on the forum with, so I just put my head down and worked, though I did take pics for later.
The gentleman who ordered these was kind enough to grant maker's discretion on the handle for the trailing point. The first decision I made was to use up a couple Suretouch odds and ends that otherwise might not have gotten used as full scales on their own, but more likely cut up for composite handles, eventually. Complementary but not identical colors with slightly differing layer thicknesses. Did you notice the color difference in the pics above?
Also that blank is one I cut out with the angle grinder a few months ago to ship to Jarod along with the 40 some blades that were laser cut. You can see from this pic that the front pin hole is quite close to the edge of the handle. This occurred due to my drill skating before biting.
Once I chamfer the scale edges, this would be very noticeable if I used pins going all the way through, so I decided to use internal pins. First I stuck two pieces of G10 together with a drop of the Gorilla Super Glue.
Then I stuck the blank to them and drilled the holes, before attaching the liners to the Suretouch. Then I drilled down ever so slightly more into the Suretouch, deep enough for the pins to have something more than just liner to grab, but no so deep that shaping and texturing would expose them. The internal pins are simple bits of wood dowel, superglued in place, which the rest of the scales are secured by waterproof Gorilla Glue white.
The result is what I guess you could call a "pseudo asymmetrical" handle. I did have to grind a little deeper on one side to expose the suretouch in the manner I intended, meaning that one scale is probably a fraction of a millimeter thinner. But I think the two side, though differing in slightly color, are quite complementary to each other.
I'm very much looking forward to refining and cleaning these ones up.
