http://www.bladeforums.com/forums/showthread.php/1481391-Budget-Flippers
So good info here.
So good info here.
Buck 830 Marksman...the flipping action on these is so free and effortless than it can be a finger guillotine when closing.
Try this "test":
With your non-dominate hand, hold the knife as perfectly vertical as you can (tip down of course). Do this by using the thumb and index finger in a pinch hold at the what would be the bottom of the knife fame/handles. Now while holding the knife in that manner, take the thumb of your dominate hand put the ABSOLUTE MINIMUM amount of pressure on the flipper tab that is required to break the detent. Very few knives will fully deploy the blade if you do exactly as I have described.
Will yours?
That's the test I typically try on a knife when I am told that it will deploy 100% of the time under any circumstances. Is that how we actually deploy a flipper blade, does it even matter ? No, but It was interesting to learn that out of all my knives only one passes that test 100% of the time.
That is the first time ever that I could successfully break detent without fully opening my CKF MILK. However, my Olamic 247 passed that test rather convincingly.
Try this "test":
Will yours?
One of the very best is the cheapest--Kizer Intrepid, and not the Ti frame-lock either, but the sub-$100 VG10/G10 version.
This is a pretty decent test, though it favors knives with rock hard detents a bit. I tried this on a couple of dozen of my flippers, and only a handful flip every time that way. The Kizer Splinter was the least expensive of the knives I tried that passed your test (~$120). The next least expensive knife that passed was my ZT 0450, and my 0450cfzdp also passed, but all of these knives have really stiff detents. Some of the knives that I think of as far superior flippers overall fail, but always flip hard in practice and have much smoother overall feel.
IMO, this is a great test for determining if a bearing flipper has a strong detent, though.
"best" in what sense?
- Blade opening speed
- Smoothness of action
- Failure rate (i.e., chances that the blade will not be fully open / lock engaged)
- Amount of the force needed to pull the flipper tab
- Magnitude of the sound when the lock is engaged
- Strength of detent
- Necessity of certain flipping technique (e.g., push button, light switch, or both)
- Comfort of your index finger tip (e.g., is it sore after 10-minute non-stop flipping)
- Level of control you have over the flipping action (faster, slower, or stopping in the middle)
- Availability of other opening methods (e.g., thumbstud, thumbhole, or none).
Am I missing anything?
I second this. I have both versions as well, and I just can't sell the Vanguard Intrepid cause it's so awesome. The weight of the blade definitely helps, but Kizer is absolutely killing it with their flipping action IMO. Even the 3" 3404 flipper on washers that I have from them has better action than a good number of bearing knives I've had.
