I would argue that the motion used in baton work is near identical to that used when chopping and is every bit as fluid a motion.
In addition the force of the impact is spread out over the spine instead of the edge as well as a portion being absorbed by the cugel (thus the indentations in the wood of the baton)
Also the size of the baton will influence the stress level placed on the knife (a wider cugel spreads out the impact area)
I have seen edge damage and failure from chopping, but never from baton work.
Torture tests well beyond normal limits doesn't help the argument, though they do make fun reading. What we end up with are manufacturers protecting their image by overbuilding knives.
Anyway, when batoning, the only way that this will result in the same senario is if you hit the spine exactly perpendicular, right at the middle of the center of the cut, and at the same time, press down on the handle the right amount (you do this before the impact unless you have superhuman reflexes) exactly inline with the force vector resulting from the impact of the baton. If you are off on either one of these, the blade will twist in the wood, either up/down, rotate, or a combination of both.
I was using around two foot lengths of dowel, and much wider swings than I would when batoning, and had a friend hold the knife. The knife was just some cheap fixed blade, and all I did was keep breaking the dowel off. Your biggest problem would be if you missed and whacked the tip hard, especially sideways.
but this is because chopping knives are generally far heavier, and get used for far more difficult tasksYes they are built to take those forces as well. When batoning you can avoid many knots that you could not when chopping (by selecting where you place the knife before you start) and you don't need to remove as much wood, no wide notching for example. With a batoning knife you may attack the wood from different sides (I think Jimbo refers to this as siide notching), but it is more effective than trying to use the same size knife to chop with.
In general, to me, batoning class knives are thin and light (like a mora), that could not be used to chop very well at all, with batoning you can get the wood down and split. These knives are thin (far thinner than 1/8" more like 1/16")with very thin edges. I have never damaged a knife from baton work.
For example take a decent sized blade (14" or so) and sweep it down the side of a small tree shearing off the small dead branches. The edge can easily hit one of the branches sideways, when batoning this isn't a factor.
If I needed to remove those dead small hard limbs while batoning, I'd sweep down the trunk with the cugel, not very romantic, but effective. You have used the spine of your chopping blades for the same effect.
Using a baton for felling is a very useful skill though, as it greatly increased the functional abilities of the knife. It is something that can and should be practiced often
As should chopping![]()
Take care,
Chad
Proper technique is an issue for both chopping and baton work.
Now now! First of all, there are a lot more minimalists these days than the "go into the wilderness with naught but a knife" types, so that might explain most of it. More over, the one's that get carried out are almost always inexperienced, or tried to push their experience into too extreme an environment. It is likely that these folks would have to be carried out even if they had a good chopping knife!Minimalist hikers and campers are too often dragged out by rescue personnel.
