I tried them once when I first started out, I didn't like them.
But I generally work with Very Hard steels, and higher alloy.
Also since i was a rookie, maybe I wasn't pressing hard enough? All the still I was unimpressed at the time.
In my experience the razorstar belts need significant pressure to break down, their product brochure makes it look like they are geared toward automated grinding or heavy pressure applications. They worked great for profiling or on a surface grinder but I prefer some of the VSM lines like 880 or 885 for freehand grinding bevels.Some people tried the new RazorStar belt and liked it. IIRC, it needed less pressure to cut well and break down the grains? Actirox, RazorStar, Cubitron 3's, etc have all come out in the past few years and seem better geared to knife makers who hand grind versus using machinery to grind blades.
I just received some new belts including Razorstar 36 grit and a Blaze 980P in 24 grit. Haven't tried them yet, but if they work as I expect I'm guessing I can double the time I spend hand sanding...
I go straight from 36 to 120 and have had zero issues.I was joking that it will double. I can only imagine what 24 grit scratches will look like. Luckily I got some 50 and 80 to clean up.
Yes, I've got lots of different belts including some flexible 120s. I don't go through too many different grits on any one piece.I go straight from 36 to 120 and have had zero issues.
Yes! Great belt. Eats metal like crazy and lasts longer that I expected. I have never had a single knife making buddy of mine like Norton Blaze belts. Neither do I. I was astonished at the positive reviews I read when I opened this thread. They last about one blade, maybe a second and that’s it…..I’m just polishing steel at that point. I like Cubitron and some VSM belts for stock removal. Headed to Pops in a week or two and will try a few more Razorstars.Anyone tried Norton Razorstar?
Not being a jerk by any means but HOW ….enlighten me please. When I started out 43 years ago I started at 60-80 grit and transitioned to 120’s , 220’s, 400, then to 600. Whole lotta steps and I could mess up at any step.I go straight from 36 to 120 and have had zero issues.
Have you tried ceramic structured abrasives? Norton U936. In 120 they cut longer and cleaner than regular 120 ceramic belts.Not being a jerk by any means but HOW ….enlighten me please. When I started out 43 years ago I started at 60-80 grit and transitioned to 120’s , 220’s, 400, then to 600. Whole lotta steps and I could mess up at any step.
If I see anything new and practical that makes sense, I’m all ears. I’d love to hear your technique on going from 36->120.
Mostly just the Cubitrons. Worked ok.Have you tried ceramic structured abrasives? Norton U936. In 120 they cut longer and cleaner than regular 120 ceramic belts
I use Ceramics for both... currently my favorite belts in both grits are the Actirox for 36 and VSM plus for 120. Like Taz said the 120's are more than sufficient, removing metal quickly (and thus, removing the 36 grit scratches quickly). I actually don't have any grits in between the two and I grind a variety of steels and different grinds (hollow, flat, and convex). I've done M390, Vanax, Cruwear, and S90V. The higher wear steels I don't take above 120 (or 220 at the highest) but I can get a very clean finish w/ no deep 36 grit scratches left without needing an in between belt.Not being a jerk by any means but HOW ….enlighten me please. When I started out 43 years ago I started at 60-80 grit and transitioned to 120’s , 220’s, 400, then to 600. Whole lotta steps and I could mess up at any step.
