Got a PM2 yesterday, and I'm having a bit of trouble with the compression lock. I'm sure I need to build up the muscles to operate the thing smoothly, however, I forgot that I cut (smashed) my right index finger a few years ago and it's still a bit sensitive. Lol, I don't know how I forgot about that. Most of the tip has very little feeling, and the sides are extra sensitive. I'll have to use my thumb until I get it figured out.
If there's one thing I learned with this knife hobby 'thing,' it's the importance of muscle memory. Without it, it can be easy to get careless and cut yourself.
I've been trying different locks. I have a Gerber with the FAST system, liner-lock, back-lock, Axis and now compression. After building the muscle memory, I like all of them.
I amnot no fancy boy, I weant my last folder to be about function, non foo foo. I chose an Emerson CQC-7 as it is functional, does what I need it too do, and hope I never have to use it for the purpose the knife was built for. The defending of my life. JMHO
Generally, I'm not a Spyderco fan (heresy!), but the PM2 is my FAVORITE knife and one of the major reason is the compression lock (once you get the blasted thing adjusted correctly, since they are apparently incapable of doing it from the factory)... so compression lock is #1. #2 would be SOG's version of the Axis-Lock, which they call the Arc-Lock. #3 would be the Benchmade Axis-lock, although (again heresy!) I find they generally work smoother on my Ganzos than on my Gripitians/Mini-Griptilians (which are the only Benchmades I have).
vanslem6, I didn't read your post before I started this message. I'm sure I've told this story more than once here, so I'll attempt to keep it brief. You are probably having an issue because it is not adjusted correctly, because Spyderco seems incapable of shipping a $100+ knife adjusted correctly. There is a video about this on YouTube Lock Stick on Para-Military 2 & Spyderco Warranty Fail?. I had exactly the same issue when I got my first PM2 (and my second, about a year later for that matter). I contacted Spyderco to ask if this would be something that would be covered under warranty. The reply I received, as the video mentions, was that I could send the knife to them with a check for $5.00 return shipping and I might have to pay an additional $20.00 if it wasn't a warranty issue... so they actually didn't even answer my question. This left me with a very poor impression of Spyderco's warranty service... I have dealt with both Kershaw and SOG with no such issues.
Anyway, since I wasn't going to send my knife in under those terms, I did a bit of searching, and found that you must loosen the screws for the stop pin on top of knife, use some needle nose pliers or such to rotate that stop pin a bit, retighten the screws and try again. Repeat this, rotating the stop pin, until you find a spot where the compression lock works properly. Then retighten the screws with 243 LocTite. I'll admit that I PERSONALLY don't understand how this affects the tightness of the compression lock, but it does. :thumbup:
And in response to SliCed's comment about taking down a PM2, by FAR the worst part, if you are going that far, is the lanyard insert at the end, because it is peened (not sure that is the right word for it) outwards at both ends, so it has to be kind of pried out and back in, which isn't easy. Also be aware that the blade pivot insert is not reversible and is directional (may sound obvious, but through me for a MAJOR LOOP for a while once...).
I agree with you here. The Para 2 is easily one of my favorite knives, and imo the compression lock is currently the best choice for a folding knife, but it has its issues. I actually do not disassemble it all the way. I loosen the screws and get into the pivot and the washers and quickly wipe down the liners without taking them out. I don't have a good reason to force the lanyard tube away from the scales, so I don't. Also, to add to this, even though this is one of my favorite designs, there is more that Spyderco has done that makes this knife not work correctly sometimes. http://www.youtube.com/watch?v=FXm1qk3nEGQ This video shows that blade play can be created by Spyderco drilling the holes for the pocket clip right below the washer, and those holes build tiny mounds around the pocket clip holes which cause the washer not to sit flush with the liner. Also, people have said that they have rid sticky lock and loosened the action on the knife by taking out the lockbar side of the liner, and bent the lockbar backwards to reduce lock tension on the tang. I don't know if I recommend that, especially as a first solution.
My first Para 2, I thought I had the blade play because of the video I mentioned, but it turned out (which was obvious when I got it) that I just needed to tighten the pivot screw. I didn't want to mess with it since I was beginner, but I took it down one day, and put it back together and the play was fixed, which is why I recommended that. The Para 2 had come to me with the pivot screw noticeable elevated and not screwed in all the way, but loctited that way. So, yes even Spyderco, which I am a fan, can ship out knives in less than perfect order. -And you're not a heretic-![]()
The thing is, while Emersons do have a great reputation for reliability, liner locks in general don't have the greatest reputation for consistent reliability or lock strength compared to other locks. Also, liner locks, backlocks and button locks are the most common locks found on "gentlemen's knives", so I'm not sure what you mean when you're talking about "foo foo" locks.
My personal experence is with the one Emerson I own. There are a lot of people who talk bad about Emersons. I think a lot of the haters are INTERNET TROLLS.
