Okay I just gotta post these before I hop on my bike and try to ride it home. I have a half sack of ciders in me, (yeah I know it should be beer but I got this thing with gluten and well you don't really need to know about that now do you?). Anyway, I hope that these pics are in order and I just have to say how impressed I am with my ability to type at this point. Sorry to offend anyone, just please enjoy the pictures and Google 'Take Five' by String Cheese.
I'll try and post the other pics Nick sent sometime before I pass out so please stay tuned, (that's Canadian for 'stay tuned'
Lorien, I think you're going to really like this next couple of photo installments
Lemme know what 'ya think!
Picking up where we left off. It's time to feather the edge in. It's currently flat ground, and is FLAT on the bevel. The current edge is about 0.015" thick. I go to the KMG with a slightly broke-in 220grit belt, and run it against the tiny little slack area between the top contact wheel and the flat platen. This is one of those things where I suppose it's good I can grind free-hand because I don't know how you'd do this part on the tool rest (although that doesn't mean you can't!);
Close up of what's happening with the above process. I am not worried that it's not feathered smooth yet;
Hooray for the Beaumont Metal Works (Rob Frink) rotary platen!!! Actually, I hated it at first because I wasn't really sure what to do with it. Now I LOVE it. With this attachment, it is very easy to blend that edge and feather it in nice and smooth;
Here's part of why I used to dislike it though. The "give" that it has is great for the main part of the bevels. However, I like nice and crisp plunge cuts, and I could never get the rotary platen to go down into my plunge cuts. You get a faceted look like this;
Enter the "GATOR" belt. This is a structured abrasive belt. I pretty much hate them for everything else, but LOVE them for this. Because of the backing, and structure of the actual abrasive, I can run the belt right up into the plunge and smooth out those facets in the last pic;
Making a pass against the rotary platen with the Gator belt;
With one single pass, almost all of that has been smoothed out. I used to do this part completely by hand with sand-paper;
Now many makers have seen or read about SR Johnson using cork belts with amazing results for his hollow ground knives. I tried it with hollow ground blades and it worked exactly as Steve explains it. However, with big, flat ground blades they didn't work for crap (for me anyway). Then I got the idea to try them with the rotary platen and some Brownell's Polish-O-Ray. This is a well worn (as per Steve's instructions) 220 grit cork belt loaded with the 240 grit buffing compound;
Ooooooh... SHINY!
And that is why I now like cork belts again.
Back to the 9" disc with some 320 grit paper. I also took the pic at a specific angle. A fella emailed me about the tapered disc. This disc has a 1 degree taper (Beaumont Metal Works). The REASON for this, is when you're sanding/grinding long blades like this, the blade does not make contact with the "uphill" side of the disc. Many folks (myself included) envision a tapered disc as a big cone, that you couldn't possibly get something flat on. However, the taper is so slight, I have had ZERO problems with that, and I like it very much. You can clearly see I'm making contact on the left (downhill) side of the disc, but it's clearing the other side. That gap is exaggerated because of the distal taper in the blade;
