daizee
- Dec 30, 2009
As you go higher, belts with some give to them let you get into not-quite-flat areas. Cork, scotchbrite, etc. - at the risk of washing out crisp surface transitions. The not-flatness is probably on the order of 0.001". Hard to spot with a straight edge, and "flat" is really only meaningful in a particular line across the blade at a given point, not across the surface as a whole. Almost no blade is technically flat from plunge to tip unless it's a rectangular shape with a die-straight edge.
Also, I truly believe that a good belt finish is technically more difficult than a hand finish - but less laborious. Since you're just starting, you might consider learning to hand-sand now to truly understand what's happening with your surfaces.
Clamp the blade flat to a knife board and get at it with some 180. About 30 seconds will show you exactly what's up with your surface, and you can bring it to a "flatness" that's hard to match with a belt. Then the following grits proceed fairly quickly. I'd call 360 or 400 the minimum for finish. Or if you're sanding pre-heat, just do 120 or 180.The first grit is the hardest as you clean out your tool marks. As your grinding gets better, this step will be faster, and you'll have a really good idea how reliable your hands are at the grinder.
