Not at all.
Potato, potatoe. Better tools work more efficiently, but grit size is grit size.
I go from "C" (coarse) diamond, to fine diamond then to waterstones on the Edge-Pro:
220
400
800
1200
Then to 2K mylar tape
then 6K mylar tape,
then to plain mylar tapes sprayed with 1 micron CBN,
then .5
then .25
then .1 micron diamond.
Sure, if you just wanna do a lazy half-assed sharpen job...![]()
My usual two grit method must really suck. I only get edges that pushcut free-hanging newsprint >6" from point of hold -- OK for spreading butter, I guess.He is missing the .05 micron 3M lapping film step, definately not enough steps in there! Only 12 grits is just being lazy!![]()
You really got something against me don't you?
Every company has a set level of quality control and the higher that quality control the better the final product. For example: would you rather have chromium oxide from harbor freight or HandAmerican?
While it is true that a 15 micron diamond plate will give a different result than a 15 micron ceramic due to the shape of the cutting surfaces, once you are down to the higher grits for finish work, this no longer applies.
The whole grit is grit issue....... well you can think of it as all being the same but its not. I can tell the difference between 0.5 chromium oxide and 0.5 diamond, especially when used on different steels. Just because some can't does not mean its all the same.
The HF vs HA comparison is also missing many variables like binder and purity. Bar compounds are not all compound.
