- Sep 19, 2001
No, they don't cut steel the same.and the fact that one abrasive is harder with sharper corners and the other soft and rounder makes no difference if the same size ? they will cut the steel the same ?
when i say they don't cut the same i don't talk about speed, i talk about how deep the scratches produced are. i highly doubt diamonds and CrO at the same size will leave the same finish.
While it would seem theoretical, I would expect abrasives of a certain size to leave a scratch pattern with a similiar spacing, but different abrasives to leave scratches of a different shape.
I would also expect harder abrasives (diamonds) to leave deeper scratches,
a scratch pattern is determined by how deep the abrasive cut not by how far from each other the scratches are because there is no space between scratches no matter the grit size.
The DMT stones go up to 3 microns, which they call 8k grit, but 3 microns is more like 5k. So with waterstones, it would take over at 8k. You could also go onto 2 micron diamond paste, or lapping film.
I've found the Shapton Pros to work well with all steels, as does the DMTs. Some stones would just skate over stainless steels.
stitchawl, you're wrong too...J/K
If CrO2 did indeed leave a knife sharper than .5 diamond, would that be because it broke down in use, because it was used on a different substrate, because of a technique difference in use, becuase of easier/tighter grading of the medium, or because of its shape?
