DanL
I radiused the platen on another 1x42 sander I had here, though you could do it on the slack belt of the sander if you only have one.
For this to work best you need to do two things. First, grind material off of both edges of the platen until it is approx 2" wide. The platen on my sander was a bit wide to start with, so had to be narrowed. Then I just proceeded to round over the edge of the platen a little at a time using the belt sander until I get the profile I want. You can either round it over just a bit, or to the point that it it rounded right from the front edge of the platen to the back. It also helps to put a little radius on the top of the platen, and round the corners a bit. That way they won't dig in if you're slack belt sanding above the platen.
Removing the sharp edge on the platen helps the belt life since things are less likely to dig in and grab. It also helps if you are trying to cut tight radiuses with the belt.
The best thing is that you can use that radius to get a consistent 'shoulder' on the back edge of the blade bevel with some practice.
From the other posts. There are two ways to cut a tight curve with the sander. One is to use a stiff backed belt, so that the edge digs in. Most of the 36 grit belts I've used are twice as stiff as a 50 grit and work good at that, and at nipping errant fingers. The other way to cut a tight curve is to run a thinner back belt off to the side a bit with the belt adjuster, and work the belt right over that radius. You can get into some pretty tight curves, and cut with more control than trying to use th square edge of the belt to dig into the material.
Word of warning. If you use the adjuster to run the belt off the side of the platen to do work, alternate doing it on either side of the platen from time to time. I always liked to use the left side for cutting tight radiuses, and eventually I ended up wearing the left side of the drive wheel more on that side too, so the belt tended to work over that way, and became hard to adjust back the other way. After about three years of use I finally ordered a new drive wheel for mine which should be arriving any day.
Disclaimer, the Sears 2 x 42 isn't a commercial sander. If you want it to last, do some preventive maintenance, like taking an air hose or compressed air to blow out the crud from inside the motor. I didn't and finally shorted the motor, which is now why I'm running it using a scavenged 2hp tefc motor to run it now.
madpoet
madpoet
