If in doubt, keep it out.Thank you for your very interesting comments.
It is difficult to judge whether the detent is strong enough, especially with systems like the crossbar-lock or the button-lock.![]()
I doubt everything you said in the first two paragraphs represents facts. Unless, you are buying counterfeiters products.They are not strong enough to prevent accidental opening. They do not have a bias toward closure. One of my coworkers jumped down from a counter top once, his knife opened in his pocket. It was a cross bar lock or a shark lock, I forget.
You can test these easily. Just hold it (blade down) and shake it. It'll open. The heavier the blade, the faster it opens. Some Demkos have such huge/thick blades that make this super easy, but even a thin Spyderco Military 2 can do it, just takes a bit more force.
I still carry and use these knives, but I'm much more careful about how I carry them... always use the clip, spine always toward the pants seem, tip down if possible.
I recommend a pocket fixie instead.Since the 90s, I used to carry my knives clipped to the edge of my Levi's 501 right front pocket.
However, there is a real "anti-knife" hysteria in France these days. I therefore want to adopt the most discreet carry method possible.
For a while, I carried a Spyderco Delica without its clip, loose in my pocket.
That is the size of knife that works for me, and I don't keep anything else in that pocket.
I would really like something a bit more "modern" (especially using different materials).
That is why I am wondering which types of locking systems I might consider, in order to reconcile my need for discretion with the style of model I have in mind.![]()
Perhaps a slip joint in a leather slip should be considered. Then it is actually impossible to open and cut you, even if there are other objects in your pocket. I carry one every day and rather enjoy it. Granted, I also carry a modern flipper in addition to the slip joint, I still never leave the house with out both. There is a plethora of options out there, from more traditional style like GEC's, to something more modern like a Jack Wolf or ABW. Then you also get to tailor your personalization further with the leather slip, I particularly like Sage Grouse slips, and he has an amazing sizing options for getting the right size slip for your knife.Since the 90s, I used to carry my knives clipped to the edge of my Levi's 501 right front pocket.
The simple solution is to tighten the pivot. It will make it more difficult to open, both intentionally and unintentionally. Either that, or use a pocket organizer or knife sheath/slip.Lately, I’ve mostly been carrying a Sage 5. I like its ergonomics, the shape and thickness of its blade, and its locking mechanism.
But I worry about an accident if I just toss it loosely into my pocket, even if there’s nothing else in there.
Button locks need to be tested in-store if possible. If they open inertially without pushing the button, they're not safe. The Civivi Outlaw Muk is one that locks closed as well as open, as do the Milwaukee Fastbacks.Thank you for your very interesting comments.
Easiest solution: Put the clip back on the Delica. Cut a piece of kydex to fit your pocket, then clip the Delica to it. Still at pocket top, clip unseen by LEOs and other sheeple.Since the 90s, I used to carry my knives clipped to the edge of my Levi's 501 right front pocket.
There is something wrong with those knives. Statistically speaking, very wrong. Unless, a lot people speak up and verify it as fact.And yet facts exist whether or not you believe them. I am easily able to get my Demko to open with a shake, same goes for my cross-bar locks. I fixed the detent on my user Spyderco comp locks, but they suffer from weaker detents as well.
A Spyderco opening with out manual manipulation? Even they would want to know what you are talking about.
