Bill DeShivs
- Jun 6, 2000
Frog Lube is basically coconut oil.
It can't penetrate metal-no lubricant can.
penetrating oil/lube indeed doesn't penetrate into metal. its a marketing term they use. but... its not completely false.Frog Lube is basically coconut oil.
Stitchawl-
I didn't say Frog Lube was bad, did I?
wonder if you used Fluid Film if the same results would be had.No, nor did I suggest that you did.
I did, however, ask if you could explain why the steel that gets exposed AFTER application of the Frog Lube somehow manages to remain free from rust. I can't explain it. This didn't happen when I was using Sentry Solution's 'Marine Tuf-glide.' The areas that got nicked up in combat would be forming rust within days of combat. After a day of fencing, these blades really get bashed about. No so with 'Frog Lube.' It really is as if the stuff penetrated the steel... although we know that can't happen. And it's not as if the lube is dripping down the blade, either. It's applied to a warm blade, allowed to sit for a while, then all excess is wiped off. The blade feels dry to the touch.
Stitchawl
Hi,No, nor did I suggest that you did.
Stitchawl
I use G96. A gun cleaner/lube product. I use it on anything that moves and needs lubrication. Guns, knives, squeaky chairs, etc.
Hi,
Maybe its because coconut oil is more like coconut grease (solid),
so when its applied to blade,
it fills and sticks to the surface scratches/pores,
and later after metal/metal contact
some of this excess grease can ooze/flow from the surroundings
to block the air/rain
