- Nov 10, 2007
do any of the mora's have laminated blades?
So... exactly what the Cold Steel Spike is not? The Spike looks about 1/2" wide, made with 7/32" stock. That'll make the primary grind 24 degrees. Add cheap 420, and you have the makings of a pretty useless cutting tool. Unless your intended utility is stabbing people, which the Spike would do pretty well.What I am looking for is an easy to sharpen, general purpose knife to be used for anything from cutting up raw chicken, to opening boxes. I do not want it to be too 'flashy' or 'evil' looking, Just Pure function.
Read the pages that are linked to you? 17 Moras are laminated on the page linked to you 10 posts ago. That means a fifth of the page was all laminated knives.do any of the mora's have laminated blades?
What Happened to commitment?I have made up my mind to get a cold steel spike. Please spare me the 'cold steel sux' comments- Because I have already made the decision.
Commitment? He doesn't owe Cold Steel anything if the numbers come out on the side of another knife. Read the rest of his first line: he didn't want the Spikes brushed off because people didn't like the company that made them, butWhat Happened to commitment?
He was willing to accept a better knife in the same price range. All in all, a much more intelligent approach than you are pushing here. I don't appreciate trolling.Unless there is a different fixed blade knife which you think is much better (for the same price),
I was under the impression that the flat ground, zero-edge would be easy to sharpen... I could definitely be wrong.
From what I am seeing, though, I will probobly choose a scandinavian style knife.
And don't let the triangular grind fool you, they are sharp! And they will cut most things pretty well.
Cannon916 said:but my friend back then stabbed a telephone pole and the last inch of the blade bent at a 90 degree angle. Don't know if I would trust them, even if they are low priced.
So you wouldn't trust a Mora because it's been shown not to be a boar spear...?
Huh? Did I stutter? I said my friend stabbed it into a telephone pole, not a boar. What are you trying to say/imply/infer/hallucinate?
You will find the Moras are excellent slicers, and perhaps eventually you can try more expensive Scandinavian knives as well. Whatever you turn to, though, thinner is better for slicing, thicker is made for stabbing or prying.
Cold Steel also makes some AUS8 and 4116 knives in your price range.
