Some recent additions to the collection.
First up is a vintage Seymour-contracted blade still in its original paper wrapping. Rather than being made by Shroeckenfux like they are at present, I believe this one was made by a now defunct firm by the name of Redtenbacher, but I'll have to consult with the experts on that point. The forging is, if anything, actually worse than on present ones--the rib and bead are very shallow and their walls are quite widely spaced, and the set of the web is atrociously low to the point where I would call it a quarter-set. Note the "polished" toe of the blade (which is awkwardly triangular shaped like American pattern Redtenbacher-marked blades were) and the absence of a hanging hole like those seen on present production. The one cool thing about it is that it has a nice crowning to the blade.
Next up is a North Wayne Tool Co. "Little Giant" blade with the original labels mostly intact. It's seen use, but not much. These pieces were made from laminated stock. Unfortunately it seems that whomever did the forging on this one was a bit of a novice as the stock is heavier and thicker than their usual, and the forging neither as crisp as usually exhibited nor as deep. It's still a nice blade, but a bit rough-cut. I was originally going to keep this one in the collection as a display piece but after receiving it and assessing both its condition and quality I would rather use it. I have a Little Giant bush blade, by contrast, that has picture perfect form.
Lastly, here's an unusual blade with a notch and hook at the base of the blade, presumably as a means of preventing choking of stocks in the span between the heel of the blade and the snath much like a grass nail. The tang is stamped "TRYON" on one side of the tang and an indistinct stamping on the other, but it bears an odd resemblance to the "KELLY" stamping on the TrueTemper weed blade I use on that blue snath of mine. The blade was not modified at all--the hook is original. I'll be restoring this one to see exactly how it performs though I must say I don't like the sacrifice of edge length to prevent a problem that I only experience under extraordinarily rare circumstances.
