Gollnick said:Who here hates SLOTTED?
And who hates Phillips just a little less than Slotted?
Keith Mayton said:I've never had a problem with them either. As long as you don't overtighten, or try to remove one that's been red-Loctited without first heating it, they work fine.
Torx and their drivers are not that common -Midget said:they are awful. who's with me?
mosplat said:i like torx so far.
but i've had one problem that i haven't pursued.
i think i may have made the loctite mistake
when trying to remove the clip from my crkt apache.
the torx wrench (not the screw) stripped..
so... heating it up you say?
Watchful said:Henry Phillips invented it in the 1930s, somewhere, and intended it for use in assembly lines...where it saved a lot of money with guys working at high speed. It's designed to go in quickly, but was never designed to be removed!
And can be easily removed!Gollnick said:(Torx)... is designed with machine-vision in mind. It features many of the same benefits of Phillips, self-centering, high torque, low camout, and it works great with high-RPM drivers.
