I specifically said flat rock as it is used in the context of those explanations for low HRC and ease of field sharpeningThree hours? Really? To sharpen a knife?![]()
I had no idea you could find norton whetstones in the field and bush. Packed in a blue boxes at that....whereas a softer steel could be sharpened on any old flat rock you should happen to find.
No, mater of fact I can do a lot better than that, but...With respect, that might be the best you can do with a flat rock, but you're selling the whole flat rock concept a little short.
Very popular explanation. I've heard that before a lot. Although, one thing that is very certain, softer knives are more cost effective for the manufacturers to make, in short and long term. Production is faster, costs less and induces less wear and tear on the equipment. It's definitely a serious reason. Abusive users, most likely inexperienced in sharpening is another point worth considering. Altough, with all respect to 1095 and 170-6C neither is a super steel by any stretch of the imagination.
I agree, there are cases when that is the case, but there are also light use knives and then lower hrc and added toughness gains me absolutely nothing, while I loose edge retention and cutting ability(because I have to grind thicker edge)...
As for the ease of the field sharpening, I don't buy it. The best you can do in the field with a flat rock it to either realign the edge, or minor a touchup. No way one can grind a new bevel, i.e. really sharpen a knife on that rock in any sensible amount of time. 2-3 touchups on that soft steel knife and the edge will be gone and you need a real sharpener to sharpen it, or spend few hours on that flat rock. Which begs the question, why exactly it is user friendly to have someone grind his knife on the stone for 3 hours in the bushcraft/survival situation? Harder and more wear resistant steel may not need sharpening at all with the same workload. Besides, how big of a problem is it to pack DMT diafold or simething like that in your pocket or your field knife sheath pocket if you expect surviving in the bush that long, with that mcuh of a knife work?
Considering that in most of the cases it is very hard to get steel RC exactly at a given value, e.g. 58HRC precisely... We're always talking ranges.I would like to point out that the KA-BAR tech did say "very slightly lower in rockwell hardness"
No, I think the keyword was "softer". Otherwise, it's a piece of steel and it ain't soft by any definition.and to me that doesn't suggest that they made the knives soft.
I would not call 1095 CroVan a soft steel by any stretch of the imagination.
No, I was not referring to loss of the sharpness,s but cutting ability as in the initial edge angle. 5-8 per side angles can't not be sustained by steel below certain RC values. Even 15deg per side becomes a problem for 54-56HRC steels. Sustain means used for cutting w/o being deformed on 1st cuts.For light use knives I would think that they aren't going to be losing cutting ability overly fast due to only having light use.
All I know is that my VG-10 knives take on a crazy sharp edge, slice tomatoes like they aren't even there and can be back to crazy sharp with a quick strop.
I do not question the ability of certain types of stones to sharpen the knife. After all, all of the natural sharpening stones are just that. What I do question is the statement that "any flat rock can do that", and the availability of those flat rocks, plus their performance on the average.Have to disagree. I've done more than a few field sharpenings, and taken a completely blunt knife to working sharp fairly easily- river sandstone is great for this purpose.
I'm not a mineralogistAs for being able to do this only a few times, got to disagree there, too- my record is 2 weeks, with daily sharpening on a chunk of Ohio sandstone, and the knife was still usably sharp when I was done.
Well, ok that was your survival course and part of the game.This was over a 2-week survival course, and outside sharpening gear was forbidden. My Ka-Bar got dull every day, got sharpened every night, and repeated the cycle.
when going to the field its simple as you put on your boots to index your equipment to remember the small dmt diamonds. now we can all be happy whether using a hard or soft steel.
I see rocks are a touchy subject around here![]()
According to you and the photo you post, bush and outdoor in general, is littered with Norton sharpening whetstones.
I'm just curious, do you seriously propose that the "old flat rock" mentioned in original posts is same as Norton sharpening stone? Last time I checked sharpening stones were either synthetically made, or mined from very specific places.
Hi guys,
Who prefers softer steels on knives rather than the new hard stuff?
And what is your preferred soft steel?
