What David said.Tri-Ad, without hesitation.
If he did it would rule all, but he is benevolentYou mean...Les George doesn't make a lockback?![]()
What David said.
As has been pointed out, the Triad is not actually a standard lockback mechanism. But it operates the same way. I especially like that it is self adjusting, so even if you make one your daily carry and carry it for years, it won't loosen up.
Spyderco, Cold Steel or Buck? Are there other companies that make very good lockbacks?
The Triad can be a bit finicky to disengage, and it is not the most fidget friendly.
I have a number of knives with triad locks and have never had a problem with disengaging any of them. I bend my thumb back and use the hard inner section of the joint to depress the release. That section of the thumb is hard, not fleshy. Mine fits quite easily into the depression in the back of the knife where the release bar is. Very easily depresses the release bar.The Triad can be a bit finicky to disengage, and it is not the most fidget friendly.
