What do you use to polish the washers like a fine grit sandpaper, do you ever replace them with better ones?If they can be taken apart I usually do to polish washers if needed then clean and re oil after break in.
I use 2k 4k 8k stones and then DMT diamond pastes to polish washers. work like a charm. The key is not to remove too much.
going to pick up some Torx tools & lube later, was gonna order some of the Wiha's but hate shipping.
wiha will last and won't warp/break as easily as off brands. eg less likely to strip screws.
also a good tip is to get a hair dryer or heat gun if the knife has any locktite. the heat will loosen the locktite and allow you to remove the screw's without stripping them. tho don't use too much heat or you'll melt something.
some knives require a little extra help to not unscrew on its own, use blue or purple locktite (much weaker than red locktite thebblue/purple can break free easier) or Teflon tape.
