- Oct 28, 2006
me no one else
Jerry does a detailed sharpening demonstration on his video - "Jerry Fisk - Knife Care". He demonstrates on knives of varying sizes, including (if memory serves me correctly) a small sword.
Roger
Thanks, Roger
I have not seen Jerry's "Knife Care" video.![]()
Once got a beaut of a knife from DANBO, Russ Andrews personal camp knife, and you could TELL that DANBO used the Sharpmaker on it from the edge scratching(he did a fine job, otherwise, it WAS sharp!) but the lad needed to be introduced to a leather wheel, and told him that should be his next purchase.
Best Regards,
STeven Garsson
Perhaps I missed it, but someone who should definetly be added to this discussion is RJ Martin.
Scary Sharp!
WWG
Oilman,
You need to invest in an EdgePro, a bunch of extra 120 grit stones for it, and a lot painters' tape. The 120 grit stones will set the edges below 15 degrees per side for you in no time; the replacements are because you'll wear them out with all of that reprofiling in no time; and the painters' tape is for the sides of the knives and blade table of the machine in case you don't gently wipe down your blades with each and every pass so that you don't scratch your blades in no time. The thing leaves flat, pretty edges as polished or coarse and as sharp or dull as you want and I'm proof you don't need skills to make it work.
At some point I probably will get one for profiling but I've put it off a couple of times so far.
