fulloflead said:Who's so good at sharpening freehand that they can offer me some suggestions on how to get off the angle guide wagon?
spyken said:fulloflead, I'm confused...but you were the sharpening kungfu master, right? I remember that post of yours of years back![]()
Matt Shade said:Getting a consistent angle is all about feel. Its easier to pick up if you've got a stone thats really smooth and hard (ceramic comes to mind, but others work)
Then take a knife that you've got profiled real well (thicker blades will work better learning because the edge bevel will be wider and easier to feel) and put the edge on the stone like your going to sharpen it. Rock your angle up and down real slow and you should be able to feel when you hit the flat bevel of the edge. Its really subtle.
When you get it there, start moving the knife back and forth across the stone in a big figure eight. Push and pull, really lightly. If you really pay attention you can feel when you get the angle wrong. Too high and the edge is going to hit and increase the drag. Too low and your going to be riding on the the upper corner of the edge bevel, it will have a sloppy feel. Riding flat on the bevel though has a feel all its own.
When you get the hang of feeling when your on the edge, it will get easy![]()
It isn't necessary at all to get a knife sharp, it is just necessary if you want to do it efficiently. Just like you can walk across a room by proceeding in a straight line, or move in random directions step after step. You will eventually get there in the second case, but it is a pretty large waste of time unless of course you just like walking and have the time.PhilL said:He contends that maintaining a constant angle while sharpening isn't as important as some would have you believe.
Yes, but if apply the secondary bevel next time in the same way, and further again next time, angle control is critical to efficiency. But yeah, two stage sharpening, relief and then edge grind is fundamental to ease of sharpening and makes a *huge* difference.Jeff Clark said:I don't need extremely tight angle control at this point either for performance or speed.
Jeff Clark said:Now actually on blades shorter than ten inches I usually do the last step on a Sharpmaker. I have done all my reprofiling at angles well under 15 degrees and I just do a few strokes on the Sharpmaker at 15 degrees to finish things off. It is not critical that the Sharpmaker rods actually be at 15 degrees rather than 13.5 or 17 degrees. It is also not critical that they are both at precisely the same angle. It is also not critical that I do a perfect job of holding the blade verticle as I hone. I don't need extremely tight angle control at this point either for performance or speed. The Sharpmaker is sort of optimally quick and sloppy for this work.
