- May 3, 2002
Jeff Clark said:Up at 7200 foot elevation the air is so dry that hair get hard and it is more challenging to dry shave than at sea level. I have to put a finer edge on knives to maintain conspicuous bragging sharpness.
You're preachin' to the choir, buddy.
Jeff Clark said:I adjust my sharpmaker angles by puting things under the base.
God I feel stupid! I never thought of that.
Jeff Clark said:Part of the reason that I use a microbevel is for strength. The back bevel angle is so low that the edge can roll. The microbevel provides a bit more lateral support. There is a universal problem that as you sharpen a knife blade your bevel will get wider unless you are always working flat on the back bevel. Having a fixture doesn't change the problem it just standardizes it. If you don't sharpen flat on your back bevel the fixture insures that as you work that bevel will get wider and wider. When I go freehand I am free to attack the back bevel a little, the micro bevel a little, and the area in between a little.
Interesting. I've only done the double-bevel thing once on a chisel grind knife because I put a particularly low backbevel on it but I never actually used the knife to try it in practice.
On everything else I've lowered the bevel on, the rolling never bothered me that much because I steel and strop often and can straighten it out. However, I've gotten a couple D2 knives recently that are hardened in the 60-62 range and when they DO roll they won't budge. I'm going to have to try that on those.
