- Mar 3, 2006
He is the master baiter.
Sorry, got to work and maintenance is on my machine. No starting early today.
lmao :thumbup:
Jim, it is my considered opinion that you are having entirely too much fun with this thread! Twenty pages on a $14.95 knife?!![]()
Again, that is subjective not objective.
REGARDING SKI, BIKE FRAME AND BIKE TIRE PERFORMANCE....
I'm no expert, but I'd guess one could quantify how those attributes affect the ability of a ski (of a given design under and average skiers body-mass) to grip the snow for sufficient agility while maintaining the lowest friction.
Again, not an expert, but I'd assume one desires maximum velocity to be maintained in a single direction, so the frame must be sufficiently flexible to absorb irregularities in the road and the cyclists movements that might alter that velocity, while sufficiently stiff to transfer all peddling-effort in the correct direction.
Run some tests on different tire-designs and compare times (a quanitity).
Edge-stability is strongly dependent on apex geometry and from what i understand from Landes' posts (haven't read his book as it isn't available in English yet), you need to go below 15-DPS and use careful application of lateral force and minute-precision measurements to be able to discern superior edge-stability in the Sandvik steels over PM, not really applicable to everyday knife use where too low of an apex angle simply results in edge-rolling or chipping which in either case increases apex diameter and so reduces cutting performance...
No, diamond cannot tell the difference between PM and non-PM steelsI freehand with a DMT perforated diamond plate from my aligner-kit, but you could use a DiaFold - light-weight, compact, very effective. It sharpens ZDP-189 as easily as AEB-L (skip to ~18:45)
REGARDING CARBON STEEL KNIVES...
A knife like this, it may be an important attribute that it be cheap, i.e. disposable, as it may be lost or used abusively. Also it should be easy to keep sharp or at least very thin as the user may be poorly skilled at sharpening.
Yes, Sandvik is very biased. Their summary chart pretends that 13C26 has the same toughness (ranked "excellent") as 1075 tool steel, but data to support that claim? Most stainless knife steels achieve only 20 - 40J impact toughness via Charpy. D2 achieves ~31J @60Rc, S90V gets 26J @58Rc, CPM-3V gets 95J @60Rc, L6-tool steel gets 92J @57Rc. If they can really achieve impact toughness ~90J at high hardness with 13C26, I'd like to see it! Folk would flock to the steel! Or perhaps they rank "Poor - Average - Excellent" all within that 20-40J range, i.e. hardly discernible in everyday (non-specialized) knife use.
You want an inexpensive stainless-steel that can take a fine (low micron) edge with ease - Cold Steels AUS-8 fits the bill
One would think there are simple direct and objective tests, right?
The problem is that performance always has an element of subjectivity involved by necessity. Skis are not fast until they are skied on by skiers; skier who have technique and a "feel" for the snow. Bikes are not fast. Alone, the can only lean against the barn wall. They become fast only when ridden by a human body and the interaction of that human body against what is, in effect, a massively complex spring system has astonishingly complex interactions with rate the rider will fatigue and the amount of power output they can maintain. Tire tests that exclude riders exclude the problem of road vibration tiring the rider.
As a systems engineer, I raise these examples to highlight the shortcomings of reductionism when humans are a part of overall performance. This is very much the case with knife use. The standard problem with objective reductionist tests is they sweep aside variable introduced by human use, and this gap is one of the reasons why the results of "objective tests" are sometimes objected to by skilled users who counter-claim, "that's not consistent with my experience".
This would be an example of an assertion that I've read to much counter-objections to to accept at face value. Just too many complaints about PM steels going jagged with hard use...
The emergence of PM steels bends performance curve compared to older large carbide stainless steels. The second is the emergence of diamond hones like DMT (FWIW, I carry a fine DMT credit card and use it all the time.).
Never-the-less, from a product design standpoint, you are falling into the same trap of wrongly dismissing the end user as "poorly skilled at sharpening". This is exactly the point. Advances in diamond hone technologies noted, PM steels are widely and correctly understood to be harder for an average knife owner to hone to a keen edge than fine carbide and carbon steels. Good system engineering and product design demands that the user be understood as a part of the system, not a problem that interferes with it. This is what I was driving at in raising the distinction in the different use cases that knives are designed for.
Again, I note that the relevance of the Charpy test to knife toughness as it is experienced by users is a subject that is hotly debated
let's see if we can agree on the scoring for these categories as groups.
Can you suggest edits?
COURSE GRAIN ...(etc)...
Sharpness
Edge Stability
Wear Resistance
Toughness
Corrosion resistance
Pinnah,
I find myself wondering if you know that in spite of large Carbide pullout etc.
That these metals are all capable of producing a shaving sharp edge?
So I'm pretty new to knives and only have a few. Every time I open another thread someone mentions an opinel. I had to know what it was. So I jumped on amazon and looked up the opinel #8, $12.95 what!!! Then the picture popped up and I thought no way is this cheap funky looking thing that popular! So what's all the rave about and what are you guys using this knife for?
Here is some spider poop I got off the net. It seems to go into sufficient detail without being too abstruse. Just throwing it up to spark more thoughts.
154CM and CPM-154 should both lose their initial sharpness quickly. We're talking about edge stability which is controlled by carbide volume and size. Carbides are the hard particles that contribute to wear resistance but make sharpening more difficult and reduces toughness. Steels with a large volume of carbides lose their initial edge quickly because the edges are only stable when at a certain angle/thickness. After stability is reached the edges last a long time because of the high wear resistance from all of those carbides. Most/all PM steels have a large volume of carbides which is why they're produced with the PM process, to reduce the overall carbide size. This improves edge stability somewhat but the primary factor seems to be carbide volume. This means that PM steels should actually be better, not worse, at maintaining the initial edge. Carbon steels and low carbide volume stainless steels like AEB-L are best at maintaining the initial edge. The long term edge retention, however, is lower.
So if I'm understanding correctly, high carbide volume steels might be excellent for less acute bevel angles and thicker toothy edges, but might not do as well on super thin polished edges or very low bevel angles?
That is correct.
Larrin,
For regular blades we make and use, these are the figures you will need for evaluation base.
Edge stability is measured by measuring the cord of a circle out of a perpendicular indent of a hard roll into the edge
To detect real valid differences the angle of the edge must be standardized 20° and assured 100% on each sample.
Each sample must be ground and polished the exact same way till 1 micron polish.
The accuracy of the micro-graphic evaluation needs to be in the area of less than 1/100mm.
Load needs to be 10N=1Kg,
For straight razors and razor blades the figures will become considerable smaller since the area of sharp an dull is smaller to.
In the end of the Day, you need good equipment and a allot of time.
You might find this in a University, you could ask Sherby in Standford or Verhoeven in Iowa or Jeffrey Wadsworth to support you.
Except from good guessing, i don't see much chance to find a easy way to do a cheap and easy edge stability test.
I have a couple of minutes, so i will try to address just a couple of things:
Achieving a "very fine edge" is first a matter of equipment & skill. ALL of these steels can achieve a "very fine edge", i.e. <1um apex diameter but some may require diamond plates for this. 12C27 achieving a finer edge than S110V is a myth unless you specify your abrasive medium.
Deformation-resistance and impact resistance are a function of grain structure and the size+distribution of the carbides, largely a function of carbon & alloy content and specific HT protocol. Here, more carbon allows a higher hardness for greater edge-strength, but a matrix with more or larger carbides can compromise that strength at very thin geometry. The thing is, very thin geometry already compromises strength via reducing edge-stiffness, hence relying on 15-dps or more in ANY steel at the apex. Any difference in edge-stability between 12C27 and S110V may not be noticeable because the geometry sufficient to potentiate the difference (e.g. ~5-dps) is too thin for applicable use (although I would love to see data demonstrating otherwise).
High-carbide ingot steels can place large sections of ceramic material right at the apex of a blade to give maximum abrasion resistance and strength... except that immediately around those large carbides is a weak boundary that can result in "carbide tear-out" under excessive stress (impact or lateral) hence such steels being "brittle" or "weak" in comparison to others at the same geometry. Using finer carbides mitigates this weakness. As a result, M390 steel can achieve the same edge-strength and impact-resistance as O1 tool steel with the added benefit of corrosion resistance and MUCH higher abrasion resistance... but at what price$$ ?
Finally, abrasion resistance is a function of alloy-content and HT as Jim has noted, in which case there is a substantial difference between the low- and high-carbide steels.
Fine/mid-grain steels dominate in certain markets for primarily one reason - COST. As was discussed regarding cars earlier, there are cheap cars than can get the job done relatively well for less money than a car featuring various upgrades. The question to the end user is whether they are willing to pay extra for the upgrades (when they are actual upgrades and not mere marketing hyperbole).
Jim is testing abrasion resistance and offers a quantitative assessment. Let's have one for edge-stability (Roman Landes' work) too. Then we can get into impact toughness at thin geometry (unless you just want to use Charpy, etc.), and finally we can discuss ergonomics, etc.
If the main issue with Jim's tests is that they compare knives in different price ranges, that is NOT objective. Jim is not assessing what an item is worth to a specific user, just what sort of tool performance a user can expect in one aspect, namely abrasion resistance. Of course the low/mid-grade steels don't perform well. My question is, do they perform BETTER than the high-grade steels in some other test? What test? Please provide a quantitative assessment. Thank you.
One should note there that Phil Wilson specializes in high-end PM-steel knives that could probably out-cut all competition by a significant margin because of how he optimizes HT as well as geometry... but his knives are very use-specific, an untrained user could easily break a blade in half NOT because Phil screwed up but because the users training/understanding was insufficient to the task. Not just anyone can be a race-car driver, training is required, proficiency is required. If someone is claiming that some steel is "chippy", they should clarify the HT protocol, the geometry, and the use, and compare it to another steel with those same attributes that is not "chippy" as a control. "Not in my experience" is usually an issue not necessarily because the users are different but because the objective conditions are not the same first.
In my own field, we have the same concerns about agent-involvement. The technique of one surgeon, while most effective and efficient objectively, may be non-functional for another surgeon. However, this is a training/proficiency concern, separate & distinct. IF that 2nd surgeon became proficient in the better technique, he would be a better surgeon. But what if the first surgeon is uniquely able to achieve such results with that technique? "Standard practice" is to use the best technique that can be utilized by the most surgeons while ensuring that those surgeons are as well trained as possible. We do not settle for simply teaching to the lowest common denominator, we select those able to achieve the highest proficiency, pushing the bell-curve as high as possible. It should be the same for all such tests trying to optimize performance with user+tool. For bicycle racing, i would expect designers to test their designs with selections from top 50% of cyclists and work to build a design that improves their performance. We do not eliminate the human element, rather we EXPAND the human element. If the design helps only 10% of those cyclists selected but is detrimental to 20% and has no impact for 70%, one could try to tease out 'why' for each group then come up with another design that helps 20% or more while being detrimental to as few as possible. That is technological advancement :thumbup:
No, the emergence of diamond hones completely eliminates the difficulty in sharpening one steel vs another, reducing any such issues to user error. The diamond hones ARE designed with the user in mind, which is why they look so similar to non-diamond hones. If you cannot sharpen on a diamond hone, designed to be exactly the same as non-diamond hones, then you cannot sharpen on a non-diamond hone either. If you have better luck with Crystolon than diamond, it is just that, 'luck'. The understanding that PM-steels are harder to sharpen to a keen edge is a myth began by folk using the incorrect tool for the job and then blaming the job rather than themselves.
That's why I looked to Landes' own work, a set of objective scientific experiments (as well as those of Verhoeven and others) to help eliminate the subjective element. For example: http://bladetest.infillplane.com/html/summary_of_results.html
Steels with a large volume of carbides may lose their initial edge slightly sooner depending on use. What use?
ALL of this can be mitigated by using the proper apex angle, namely ~15-DPS, whereupon all the steels stabilize (if sufficiently hardened) unless subjected to impact stress whereupon again the large-carbide steels (or those with VERY high carbide volume) fracture more readily than the small-carbide or low-carbide steels.
Yes, absolutely. But (and correct me if I'm wrong), a) it requires diamond based tools, b) one needs to pay more attention to edge angle (min angle increases with carbide size) and in some cutting applications (like wood), one can expect fast edge degradation due to carbide pull out.
You guys still talking about $10 Opinel folders here or did the subject change to rocket science or something?![]()
