- Dec 31, 2005
Mora's are great for the money .... but if you are going into the wilderness and don't fancy carrying more than you need .... the fact you could have 30 Mora's to a Skinny Ash drops off because no-one will take that many multiple Mora's .... if you just take one or even two then the issue is what can a Mora do or not do which a Skinny Ash will do ....
Well, go to Brunei and go into the Jungle where "hardwoods" exist .... in a wet climate like that getting into the "heart" of such wood for dry tinder is neccessary .... baton such wood with a Mora .... and see how it fares .... do the same with a Skinny Ash .... with the Mora the plastic handle "gives" .... the blade can snap if hit "askew" but that is rare .... hit directly they can work .... IMO you don't hit perfectly over "time" all the time .... you certainly get more than $10 worth of use from a Mora .... but that's no good if the handle seperates when you really need it .... handle issues were the most common issue in my time there where I saw a number of these being used ....
You may not need to go to a Skinny Ash to have true "functionality" .... cheap local Parang's work well .... but ultimately how much you are prepared to pay for a knife is like asking what do you think your own life is worth ....
Perhaps for 90 % of people this sort of example is not relevant in terms of liklihood of happening .... but even then for the sake of a few hundred dollars .... those who encounter the 10% bracket of needing a knife with a lot of strength have made a great choice .... and those who have'nt come across that yet .... they at least have the right knife should they do so ....
Mora's are great for the money but I would'nt settle for one if I could afford better ....
