It's possible, but if the direction of scratches on the edge was so critical, why don't we hone lengthwise?![]()
Honing is only the edge, Mr. Fowler only indicated that it increased the strength of the blade laterally. So this effect is useful for the overall structural integrity of the blade, not the edge specifically.
Unfortunately I can only give you reasons behind why buffing lengthwise would be beneficial, I don't have any data about it. To be honest, I would've guessed that the effect would've been almost negligible.
Destrall: Your explanation is a good one, easy to understand and more than adequate!
Thanks, to be honest, I know more about fracture mechanics than I do about the effects of buffing.
ok, so that applies to propellor blades ( without spending $150 yet to read the book), how does that apply to knife blades? How much of an increase in streingth does a mirror surface finish provide over other finishes?
Both are metals that can suffer from fatigue damage. Every time you use a knife you're applying a load to the steel. Although this load is significantly below the yield strength of the material, given enough loading cycles the metal can suffer from a brittle failure at a stress that is often lower than yield strength.
The effect is much more dramatic in propellor blades that go through many loading cycles at a time than in a knife that may only get used every few hours, or days depending on how much you use a it.
In fatigue the effects of small imperfections in the material are much more evident. I would imagine in the usual every day carry this would be negligible, but in a blade used in a factory all day this might be worth some serious consideration.
Once again, sorry I can't produce any empirical data to look at. Most of this information is out of a Materials text book by Young, et al, if I remember correctly.
