Yea, what they said...re-read the cautions above. Also, if the sparks hit you in one place too long it is possible to "toast" your clothing without actually setting yourself on fire...but when you go to brush the debris off your clothes, the front of your shirt or pants crumbles and brushes away too. Don't ever try and cut a curve in a way that bends a cutting wheel...this will end with cutting wheel shrapnel embedded somewhere. Don't use anything but the edge of a cutting wheel. Grinding with the side or doing anything that damages the fiberglass fabric can cause the wheel to "blow-up" (see previous comment about shrapnel). Before use, run any new wheel for a minute under no load and with your body out of the plane of the spinning wheel, just in case the wheel is damaged or defective. Don't succumb to the temptation to remove the guard. First, it helps control the sparks. Second, it only takes a second to lose concentration, change your grip on the tool, etc., and grind into a finger or a knuckle. Grinder cuts are wide, dirty, take a while to heal, and leave funky looking scars.
But yes, if you treat the tool with the respect it deserves and use it safely, it is pretty amazing how easily you can cut and grind steel, and how versatile an angle grinder is.
