- Sep 19, 2023
I am sorry you feel that way.With all the advancements in steel composition, 440C is practically junk. I’m sorry, but it is. S30V is highly affordable and outside of some cheap Chinese knives and traditional knives making it a point not to change anything about their construction, it is largely extinct. I’m sure wool coats served Soldiers well in battles hundreds of years ago, but there is a reason they have moisture-wicking technology and extreme cold weather clothing etc now. “Ease of sharpening” and “ease of replacement” shouldn’t be a factor in 440C vs 154cm/VG-10/S30V due to a heavily saturated market with the stuff, advancements in sharpening technology, and reduced cost differences.
S30v stock is more expensive than 440c/n695. Its using far more expensive technology to make it, and is harder to grind and heat treat properly. So cost is certainly a factor for the end user.
Your argument regarding soldiers in battle is a logically fallacious argument called an "appeal to extremes".
This is mostly irrelevant though because you are changing the goalposts here. Your comment was about 440c in comparison to Magnacut not vg10/154cm/etc. And the price difference as well as ease of sharpening is significant when comparing 440c to Magnacut. Sharpening ease is especially important to those in the field if you get a bad chip or roll that requires diamond cards and time to remove.
Even with any advancement in sharpening technology, it doesn't change the fact that Magnacut would take longer to put a workable edge back on a blade using the same equipment, and that if the blade was damaged or lost it would be significantly higher dollar of a loss.
