Rather, the convex edge is much thinner behind the edge than a comparable V-grind.
It has a thinner and smoother cross-sectional geometry and thus can cut with less resistance/drag than a 15 degree V-grind, but at the cost of lateral blade strength and toughness.
What I meant is that with the "heavy pressure convex" that rolls the last bit of the edge fro 8 to 15 deg, the convex edge is more obtuse <at the edge> than a V grind at 8 deg. The convex is more robust at the cost of acuteness. But, it is no longer comparable as it is more obtuse.
I can't count how many times I have read "convex edges are more robust because they have more metal behind the edge than a comparable V-edge" (Right here on BladeForums- The Leading Edge in Knife Discussion) and it just drives me up the wall.
Well, why can't that statement be true? Depending on the arc of the convex edge, I can see it having a lot more metal behind it.
If you sharpen both to the same edge angle the convex will be thinner.
Hey guys. I hear so much on here debating Convex vs Vgrind. Well, my questions are:
Why would someone want a V grind instead of convex? some say V is better?
I know its talked about a lot, but why would convex be better?
And, what do you guys prefer on what type of knives? (style and size)
I am most interested in utility, tactical, camping, combat kinds of knives. What kinds of grinds are best for what kind of slicing/chopping, etc.
Like I said, i know there are many mixed feelings, so please express any and all feelings. Thanks for the info.
There's only one problem with that image... the convex edge has TWICE the final angle at the cutting edge. There's no way it will cut as as keenly, even if it is much more impact resistant. I used to have a schematic somewhere of what a convex and flat grind with equal terminal angles look like, but if you imagine only grinding the shoulder of the v-grind to convex so that the last infinitessimal bit near the edge remains untouched, you can plainly see that a convex grind will retain less material than a v-grind of equal final angle and stock thickness (and if you're not going to keep those equal, it's hardly a fair/scientific comparison.)
Alright, I can sort of buy that... but then how do you validly compare cutting ability? You now have two different variables (actually, an infinite number of variables, given the variable curvature, but let's just lump that into one variable.)And that's where most get convex wrong, if your final edge is the same as it was when it was a V grind then you did it wrong.
Convex is a method of making the final edge angle more robust while streamlining the shape of the bevel.
