- May 14, 2012
The locks on my slipjoints fail...
lol.
I find, for myself at least, I'm much more concerned with lock reliability that lock strength these days, including how easy it is to accidentally disengage said lock. I think the Compression Lock and BBL from Spyderco are likely my two favorite locks, because I've never had them fail to lock up when opening and it would be very difficult to accidentally disengage them. The ultimate strength of the lock isn't much of an issue as long as it's enough to withstand some jostling and an accidental tap on the spine.Axis, compression, spyderco lock back.
If you are really concerned about lock strength, you'll figure out how to carry a fixed blade.
Yes, exactly. I felt very un-cool wearing a bandage for a few days.
#spongebobfailyou didn't splurge for the sponge Bob bandaid to run with the in crowd huh?
Agreed on choosing something reliable without necessarily being focused on absolute strength. For me, just about anything well-executed that isn't a frame or liner lock is all I'd ever want. For me, Axis/CBB locks seem to be the most foolproof.I find, for myself at least, I'm much more concerned with lock reliability that lock strength these days, including how easy it is to accidentally disengage said lock. I think the Compression Lock and BBL from Spyderco are likely my two favorite locks, because I've never had them fail to lock up when opening and it would be very difficult to accidentally disengage them. The ultimate strength of the lock isn't much of an issue as long as it's enough to withstand some jostling and an accidental tap on the spine.
For our "humor challenged" members , the winking and laughing emojis indicate an attempt at humor and indicate content not to taken too seriously / literally .Nope.
At one time CRKT advertised that their lock was as strong as a fixed blade. I have a couple folding Razels that this was said to be the case. Never really tested it and don't plan to. I use the Razels primarily for scraping where I need a sharp blade.If only someone would invent a folding knife with the strength of a fixed blade - a folding fixed blade!
Well I think it is bleedin' obvious iddnit . . .It’s a fixation that affects many people, but why?
Wow! This makes a lot of sense to me. I think you have altered my opinion.I'll admit that I feel strongly about this topic. For me, it's a combination of factors.
1) That an expensive knife shouldn't have problems with lock geometry and design, or any other part of its execution, even if you don't intend to use it in a way where that matters. Full-stop. To me, this is akin to wanting your sports car to be capable of the performance you've paid for, or to wanting a knife with good steel to have a good heat treat. Some things should just be correctly done. What you're paying for should be what you get, period. It's fascinating to me that people care more about Benchmade shipping out knives with blades that aren't centered than about ZT shipping knives that don't have correct lock geometry (I've seen this first hand on my own ZTs, so drop the nonsense about how it's a few isolated instances).
2) Because locks don't matter until the one instance where they do, and then they're worth the knife's weight in gold. Locks allow for knives to make plunge cuts safer, they allow for you to pull a wedged knife out of cardboard/rubber/foam/plastic safer, they allow you to get away with being less attentive regarding how you hold the knife while moving around and working (like the example above of the spine hitting solid objects while in a warehouse/HVAC work/auto work/construction/home improvement situation, and in general are going to make it easier to operate a knife without being cut. I can still be smart about how I use a folding knife and not rely on the lock to be safe, but still have the lock as additional insurance, just like how I can carefully drive a car with a working seatbelt having never been in an accident and still feel strongly about having a working seatbelt in my car.
3) Because it looks like some knife makers don't understand what they're doing. As Michael Walker would probably tell you, frame and liner locks are more difficult to get right than most people acknowledge. It seems like a number of OEMs nowadays use unsafe lock geometry, poor lock designs, non-existent lockbar tension, and improper lock surface finishes/treatments on their blades and seem to not to realize it. Why should I assume that those OEMs only get the locks wrong on their knives if those same people are in charge of heat treat/fastener choices/blade grinding/handle work/general design?
This is an especially sensitive topic for me because I've had a disturbing number of expensive knives that would reveal lock issues with static hand pressure on the spine of the blade. I don't do spine strikes to test a lock, so if the lock shifts in my bare hands or the blade closes rather than seizing open like it's supposed to, that's a problem. I have not been cut with any of my knives due to failing locks; however, I also check every single knife the instant I get it and get rid of any that have weak locks, so read into that how you will.
Get a small fixed blade dude! Maybe a neck knife would be best for easy access while working on such things.I have had a few nics and cuts over the years from locks failing. Negative pressures or jolt on the spine.
My brother had fo have surgery on a tendon in his thumb (severed) from the same brand and model of knife that had cut me 2x from lock failure). Similar situation piercing, and negative spine pressure.
I was opening a box of frozen meat. Poked the box from side, just below the top, to cut the box top off. Point made contact with frozen meat, and blink, cut finger. I was about 10 boxes in, with wet cold hands when this happened. The freezer i was pulling meat out of was -28 I believe. This was not a hard stab, or wild movement. The tip went in, and the instant it met resistance from the stacked frozen beef, the lock folded like magic.
Brother was piercing and cutting heavy rubber. We both stopped carying that same knife.
I have another liner lock that I was using, cutting water line hose in very tight quarters. I was stuffed up in a cubic hydraulic press, cutting at an awkward angle, and the knife suddenly cut through and forward. The point/ spine hit solid steel (the press weighed 40 tons) and the knife snicked closed on my finger) not a bad cut, but annoying while covered in sweat and 68 weight hydrollic oil, and powered stone grime. That knife lock never worked correctly again. Light thumb pressure would cause it to fail after that. I've had similar situations with both liner and frame lock, where light pressure would cause lock failure.
This is one of the machines (I don't own the copyright to these images) I worked on these for 5 years while completing undergrad degree).
This is what they look like before being plumed, and having the anvils and back up anvils installed, as well as power, hydraulic and water lines. Cramped working on them.
I have had multiple jobs that required curring in tight places. Farming (working on farm equipment in tight places), grainery, often tight and super dangerous places......often elevated 65 to 80 feet off the concrete on catwalks above the grain bins. Worked on a man lift 80' up in the rafters of an airplane hanger designed for jumbo jet storage.
If you ever whittle with a liner lock or frame lock, and use thumb pressure on the spine of the knife, or use your off hand thumb as an additional lever, you have pretty significant negative pressure on your lock.
I have a knife that unlocked this way, but did not cut me, because there was a notch of wood in the way.
I wouldn't be able to resist twisting that swingy thing back and forth until it snapped off and then put it in my pocket. Gosh that looks awful.Sog q2 baton, fixed blade full tang, folds open
Sure it can still happen even with strong locks. I got enough pocket lint in a relatively new and little carried back lock that it didn't seat all the way. Fortunately I noticed it before I got hurt and picked the lock clean with a tooth pick.Plenty of people got hurt from a lock failure, myself included.
