Now I know conventional wisdom says a dull knife is more dangerous blah blah blah. In my personal experience (though I hate to admit it), I'd found it not so true. I'vecut myself far more often on very sharp knives than on those which lack a good cutting edge.
Angle determines edge retention, not what grit you sharpen with.Yup, me too. Over-sharp can be dangerous, myths notwithstanding.
I only sharpen to the point where it needs to be. Anything more and it's dangerous plus you're losing edge retention.
that's what I was referring to. I assume "razor sharp" means re-angling the blade.
Hell you can polish a 40-degree blade all day and it's not going to be super duper sharp. For that you need to knock it down to 18 or less, like a japanese kitchen knife.
whatever, it's just an internet forum.
To me, "sharpening" is actually removing a fair amount of metal from the blade, usually when you reprofile the blade or when you completely redo a damaged or *extremely* dull blade. Honing or polishing or stropping happens when you smooth out an already sharpened blade.
When you get your new UmbraOps DeathDealer Tanto and bring it home and it's not sharp enough for you and you take out your super fine ceramic rod and pass it a few times on the thing, you're not really "sharpening" it, you're merely honing it. Same if you do it with a buffing wheel or leather strap or honing steel or whatever.
So if somebody says to me that he sharped his knife to a razor's edge I envision him reprofiling the blade to a very acute angle.
If he says he buffed or polished the edge until it was real sharp then that's something else.
I can whittle hair with my vic sharpened to 40degrees lol, a 18degree knife would cut better though.that's what I was referring to. I assume "razor sharp" means re-angling the blade.
you must spend a lot of time re-honing those blades!
and get dull even quicker![]()
