- Nov 9, 2006
this is beautiful
Hi Frank, I get your point. If you look at that last diagram that I referred to the blade profile effects are most obvious as the cutting performance flattens out on the right side of the graphs. To compare apples to apples lets only look at the BG42 curves. As you pointed out the worn Edge2000 blade cuts better than the worn baseline edge. Some of that is due to the difference in honing angle, but much of it is also probably due to overall blade profile changes. The difference in performance in that region is about 1 on the depth of cut scale.
The place where the difference in honing angle does show up is on the left side of the graph. Note that the initial difference in performance is over 2 on the depth of cut scale. It looks like at least half of the initial higher cutting effectiveness of the Edge2000 is coming from its more acute edge angle. The more interesting thing is the difference in slope between the two curves. The curve for the BG42 edge honed at 20 degrees drops much more steeply than the curve for the BG42 edge honed at 13-16 degrees. That means that not only is the initial performance of the 20 degree edge lower than the performance of the 13-16 degree edge, it also dulls faster than the 13-16 degree edge. That was my point. Contrary to popular impression a more acute edge dulls slower than a less acute edge.
The last plot on the web page illustrates that for ordinary wear (mildly abrasive wear) a thinly hollow ground 420HC blade can outperform a thicker grind on a BG42 alloy blade.
Take a look at the test results in the last chart in this paper. That is how knives "wear".
Hi Vivi, do you have pictures of this edges?
I put a 26 deg angle on my sebenza, he edge is about 3 mm. Yours should be 5 mm or more!
Marthijn
I stand by my last explanation of how to pull information out of the graphs. The steeper slope at the beginning of the graph for the older blade profile indicates faster loss of sharpness for 20 degree edge. The overall blade profile is not changing, that is the edge wearing down. Slopes on graphs are a measurement of rate of change of something. In this case it is the rate of change of the edge performance because that is all that would change that fast.
