- Aug 18, 2014
you can turn the blade when carving wood
no those are not
no those are not
I can agree with that. But I have a question: The best slicer for any given knife is a full flat. But take any knife that is full flat, one can get another knife that's a better slicer if the other knife is thinner and full flat resulting in a more acute angle, yes?
Same here. I find scandies almost worthless for push cutting/food prep. Once they go "deep" into something they bind up. Try slicing a carrot or onion with one. Fine for a shallow, draw cut, but so are flat grinds.
Mora Companion by Pinnah, on Flickr
Case 316-5 (drop point) by Pinnah, on Flickr
Buck 110 by Pinnah, on FlickrI can agree with that. But I have a question: The best slicer for any given knife is a full flat. But take any knife that is full flat, one can get another knife that's a better slicer if the other knife is thinner and full flat resulting in a more acute angle, yes?
What would you call this grind?
Buck calls it (and thus the BCCI Buckalites will insist that is) a "Flat Grind".
I strongly disagree. Given blades of equal thickness and height I find a full height hollow grind (such as on my Dozier Yukon Skinner Pro) to slice far superior to a full height flat grind (such as on my RAT-4). Even a narrow blade like a Buck 102 with a nice hollow grind can be a fantastic slicer in soft mediums. I much prefer a hollow grind to any other grind for hunting knives and meat carving knives.
Its a saber grind. You are oversimplifying.
I'm not disagreeing with you. Just noting that some folks refer to that Buck as a flat or high flat or v-flat grind. I believe that Benchmade refers to their similar grinds as flat or high flat, as distinguished from full flat.
I suspect that tall nature of the blade (spine to edge) helps keep it going straight through the material. I prefer a real chef knife to a paring knife for that sort of slicing for the same reason.
My conclusion is that for slicing you want:
- thin spine
- thin behind the edge
- taller blade
- no friction-causing shoulder on the grind
I believe the hollow grind attribute does not add to the slicing ability of the blade; it's more for "strengthening" the blade by having a thicker spine. If you lop off the top of the blade before the profile flares out, then you simply have a thinner blade.
There is less steel behind the edge that is why it slices better, hollow grinds also maintain a thin geometry as you sharpen them versus getting thicker and thicker on a flat grind.
Thats why I shave my face with a hollow ground straight razor not a flat ground one
but a hollow grind makes a poor wood knife.
it gets stuck in the wood when carving.
its the opposite of a scandi which is better for carving but poor at slicing.
thats why there are other grinds that offer more versatility such as convex grinds etc
