- Sep 19, 2001
powernoodle probably has it right about the low cost and ease of manufacture, because the locks don't offer practical benefits otherwise. They are "handed" locks, notequally manipulated by both hands. They have lower strength than most locks, with no weight or mechanical simplicity as advantage. The lockback is in fact stronger, and has been shown in multiple, repeatable tests by custom makers and manufacturers. the framelock is not appreciably stronger than the liner, again as shown in tests. The compression lock has the same number and type of parts as the liner lock, but is many times stronger. The frame lock puts the lockface, lock spring, and half the handle in one unnecessarily heavy metal piece that leaves a single point of failure. The lockback and other locks are stronger because the lock and spring are separate for most of them. This means components can be made larger. The larger liner lock is the frame lock, which still requires the thin cutout. This means the lock is heavier, but not stronger. An axis spring can fail. there are two of them. If a spring fails, the lock bar is still intact. A triad lock is stronger than a framelock without the need for liners.
