- Sep 9, 2015
i was looking on bladehq about different types of steels and they had one called stellite 6-k, that i never heard of and the only information on it was that it had no iron in it! anybody have any info on this steel
Read this.
http://www.bladeforums.com/forums/showthread.php/176264-Opinions-on-Stellite-6K
http://www.bladeforums.com/forums/showthread.php/800771-Stellite
http://www.bladeforums.com/forums/showthread.php/1064937-Cord-Wrapped-Stellite-6K
http://www.bladeforums.com/forums/showthread.php/545189-Stellite-6B-and-6K
but not many makers use it because it is expensive, and is not going to act anything like a steel when you grind it.
And it is incredibly difficult to machine. Really, really tough on milling/drilling tools. So, it's not only expensive to procure, but also to produce.
The M-60 machine gun uses stellite for barrels (instead of making them easy to change).
David Boye's boat knives are made of a cobalt alloy similar to Stellite. He casts to shape so there is not as much machining to do. FWIW Stellite is fairly easily shaped/sharpened with diamond abrasives
How stellite compare to infi?
Im not disputing your post (most knives are easily sharpened using diamond abrasives and I dont currently own a Stellite knife) but Boye recommends, that one sharpens his cobalt knives using a medium stone (non-diamond), as diamond sharpening will quickly remove too much material and shorten the service life of the cobalt blade.David Boye's boat knives are made of a cobalt alloy similar to Stellite. He casts to shape so there is not as much machining to do. FWIW Stellite is fairly easily shaped/sharpened with diamond abrasives
Further more the barrel of the Pig is fairly easy to change.Close but not quite the barrel has an insert made of stellite that goes about a third of the way down the barrel from the chamber. It is to prevent corrosion and wear resistance due to the extreme cycle rate of the weapon.
