I think there may be some confusion on the entire process here, I apologize for techy talk, you really can make good knives without $5 words, honest
. Perhaps we shouldnt assume that all reading this already have experience with, or are familiar with the concepts of marquenching.
First of all, much of industry calls it martempering, but I feel this is a gross misnomer and has lead many a new smith to believe that it eliminates the need for a follow up temper- WRONG. It all relies upon the fact that austenite (the internal state of steel at the high temperature) is only stable at those higher temperatures. The first temperature in the quench that it will want to transform into something else will be in the range from approx 1100-900F. where, if cooling is not fast enough, varying amounts of fine pearlite form. If you cool fast enough to avoid this, you will still have austenite. With continuous cooling the next transformation range will be from approx 500F and lower, you hold above this for extended periods for the bainite. This is marked by the Ms we keep mentioning, it is the martensite start point.
Stopping the cooling above Ms allows you to equalize the temp throughout before making the plunge into the highly stressful martensite transformation. The martensite transformation is classified as athermal which really makes little sense since it is the opposite of what that word would imply
. What this means is that it is solely temperature dependant, with time having little effect. Cool until you get 50% martensite and then stop and you will not get any more martensite, no matter how long you wait, until cooling continues.
Since martensite is completely temperature dependant , by allowing the steels cross section to equalize in temperature, you can cause the martensite to form evenly throughout. Otherwise the thinner sections would transform sooner, expanding and tugging the other sections all over and possibly causing distortion.
One very nice benefit of this is that you can put on gloves and eyeball the blade as it is cooling, if you see any distortion occurring, you still have soft pliable austenite to in there to work with so you can gently and easily straighten it. If get doubters of this in my Intro class, I have them put gloves on and I stand over them as they heat treat their favorite blade. I tell them exactly when to pull it out of the oil and then I grab the blade with my gloves and let them see that it is still nice and straight. Then I will grab it and bend a good kink in it, hand it to them and tell them that they have about 3 minutes to straighten it
. They are always believers after that.
Of course the auto-tempering effect that I mentioned is the other benefit. The gains in impact strength can be pretty surprising. Another demo that I like to do with my class is to demonstrate the interrupted quench and when the blade has cooled, I hand it around for the class to look at, and file check that it is fully hard. Then with no subsequent tempering at all I hold it head high and drop it point first onto the concrete floor. It is not good for the floor but the tip always does fine. None of it is magic, nor even a secret, it is just using the materials and the processes in a way to take advantage of simple metallurgical principles. Industry has been doing it for decades.
