It is an unfortunate downside of Sebenzas (as opposed to the Inkosi or Umnumzaan) that the risk of pinching washers is significantly higher and when you do you have to send it in. As others have said sliding the blade in the assembled knife is the best way to avoid it in the future.
View attachment 1002569 I am officially a Sebenza owner! This is by far the most expensive knife that I have ever owned and The quality is evident even in the first few minutes of owning it.
The grind on the blade is so thin I can’t wait to start cutting some stuff with it!
Sebenza thumb is such a real thing! I find the knife quite difficult to open. I think part of it is that I put my fingers on the lockbar. Also I haven’t quite figured out the correct angle to use on the thumb stud.
Thanks for the advice on being patient and letting the knife break in. I could see how there could be a disappointment in the initial action of the knife. It’s not the smoothest knife I’ve ever owned but I know it’ll get there once I break it it!
Wow this thing is beautiful!
Too lateIf you laid the knife on the spine of the handle you would want to push the thumbstud directly vertical towards the ceiling. Then in a halfmoon around the pivot.
This is unlike most folders where ifnthe knife was on the handle spine you would push the stud at a sort of 45 degree angle from the ceiling and horizontal.
This is probably going to upset some purists but I also recommend opening the knife, cleaning out the stock grease and replacing with somethinf like nano oil. Just remember it can be very easy to accidentally pinch the washer between the bushing and the scale when reassembling. Take the time to make sure everything is lined up properly.
